Help: BLOX Front Engine Roll Stopper
Old Dec 5, 2009 | 08:35 AM
MR White's Avatar
So I purchased a front engine roll stopper and have everything bolted back onto the car but the mount hole does not line up with the engine mount. If I get this to line up first then put the support beam bolts in nothing lines up and I cannot get the support beam bolts in. Help. Pointers tips, what did I do wrong. This is supposed to be a 20min install FML
Old Dec 5, 2009 | 09:03 AM
EngineeredBLUR's Avatar
The hole spacing from the mount center-line is not the same on both sides. It looks like you have it in backwards.
Try flipping the mount direction, it should line up fine then.
Old Dec 5, 2009 | 09:18 AM
MR White's Avatar
should it matter what side? It's the same shape all around. Bump, this is ticking me off. 2 hours for a 20 min job
Old Dec 5, 2009 | 10:05 AM
Its not quite the same size. Check your factory engine mount, there will be a small difference between the centerline of the engine side mount(rubber upper) and the distance to the 2 holes that mount to the car(lower 2 holes).
Old Dec 5, 2009 | 10:30 AM
MR White's Avatar
Got it, feel stupid. All I needed was to put the rear bolt in first then use a screwdriver as a pry bar. All done
Old Dec 5, 2009 | 10:36 AM
localtoys73's Avatar
that happens on all my installs
atleast it quit raining
give us some feedback on how it feels
Old Dec 5, 2009 | 11:05 AM
guyver858's Avatar
Yeah same issue happened to me too.... its because the engine moves/tilts when u take off that mount... who would've thought...haha.... the screwdriver prybar technique worked for me too. I do the same thing when changing out bushings and what not as well.
Old Dec 5, 2009 | 12:00 PM
MR White's Avatar
Just took her for a spin. Engine movement is reduced, I used to feel the whole car shift back and forth when I let off throttle now it's much smoother. I still feel some engine roll when I let off the gas after hitting peak boost. Shifts are better as well. My synchos in 2nd are on thier way out. Honestly I can't tell the vibration difference but I can tell a difference in noise. There is more cabin noise now after the install but a welcome tradeoff.
MR White
For Sale - Wheels / Tires
12
Feb 27, 2017 08:12 AM
MR White
Feb 26, 2017 06:41 PM
MR White
For Sale - Cars For Sale
Feb 25, 2017 10:01 PM
MR White
Jul 22, 2010 08:21 PM
MR White
Apr 9, 2010 10:34 AM
