Need some advice on turbo
Old Dec 8, 2009 | 09:08 PM
polak1035's Avatar
Recently the turbo on my IX went. Short on time and cash I got a VIII turbo and o2, except the the oil lines what other issue will I run into? Are there any advantages/disadvantages of running a evo viii turbo? Any feedback is greatly appreciated.
Old Dec 8, 2009 | 09:19 PM
Force-Fed Performance's Avatar
you wil have to use a longer hose for the water line and to modify the oil return to fit just cut it about a inch from the bottom flange and an inch from the top and use a hose and clamps and it will be fine
Old Dec 8, 2009 | 09:25 PM
polak1035's Avatar
Thanks for the tip other than that is there a power difference in using this turbo?
Old Dec 8, 2009 | 09:27 PM
you will be down 20hp or so but it will be fine to drive on, the 8 turbo is noticeably smaller than the IX. no biggie, our shop IX is running on a 8 turbo before the engine is taken out
Old Dec 8, 2009 | 09:29 PM
polak1035's Avatar
ahh that sucks but as long as it runs good than Im happy since its a DD thanks for all your help
Old Dec 9, 2009 | 10:59 AM
460hpevo8's Avatar
the only different between a 9 and a 8 turbo is the y pipe connect to the turbo near the starter. dont waste money buying any lines. Your evo9 lines will work with the 8 turbo. i suggest u sale the 8 turbo and get something else. it is very small man. i had one laying in my garage. Just had the new 80mm fp red put in. i love the red turbo.
Old Dec 9, 2009 | 12:41 PM
grillpt's Avatar
I know this is OT but what happened to your stock turbo for it go? Don't hear about to many oe turbo failures, at least I don't.
Old Dec 9, 2009 | 01:47 PM
polak1035's Avatar
front end hit damaged the turbo I just hope by buying the evo 8 turbo Ima get a lesser of an evo lol
