Driveshaft clunking
Old Jan 28, 2010 | 09:11 AM
dambikeracer's Avatar
Originally Posted by inf0
wow just saw the vid mine isnt no were near that bad yet
+1 But I always want my car to be perfect.
Old Jan 28, 2010 | 11:03 AM
Matt D.'s Avatar
I say do the driveshaft bushings and rearend (mustache bar) bushings first, see if that helps at all first. I know that Kracka and Scheides have them installed, I have Beatrush ones waiting for a warm, dry day to be put in.
Old Jan 28, 2010 | 11:49 AM
Kracka's Avatar
https://www.evolutionm.net/forums/se...trunk-bar.html
Old Jan 30, 2010 | 02:29 AM
hussein's Avatar
wow
Old Jan 30, 2010 | 05:50 AM
bbyevo8u's Avatar
when i back my car out of my driveway for the first time of the day i get a big clunk then it sounds like some clutch chatter when i push the clutch in to take it out of reverse but this only happens the first time i move my car then i dont hear it again? i was thinking it could be my rear diff separating a bit while sitting over night then when i go to drive it for the first time in the morning it pulls back together making a clunking noise?
now i'm thinking it might be the driveshaft?
Old Jan 31, 2010 | 09:17 PM
Matt D.'s Avatar
My car would make clunking noises at weird times like that as well, but typically only when the driveline was having the slack taken out of it, like going foward, then going into reverse, or accelerating slowly then suddenly stepping on the clutch and letting off the gas.
Old Jan 31, 2010 | 10:27 PM
xRoguex's Avatar
I have every bushing under my car replaced. Beatrush in the drive shaft, and the ES master kit for control arms, rear end and mustash, etc. Its amazing. One of the best mods I ever did.
Old Jan 31, 2010 | 10:31 PM
NJ_EveOhVIII's Avatar
^^+1 made a big difference
my driveshaft was clunking (a horrible noise)when i put the new rear diff in. the bolts on the arms of the rear diff were ever so slightly loose i tightened them up and it was fine.
Old Feb 1, 2010 | 04:36 AM
bbyevo8u's Avatar
yeah my car kinda does that too i wonder if my driveshaft is slowly going or could it be clutch chatter?
how does your car feel with the ams driveshaft?
Old Feb 1, 2010 | 07:54 AM
Matt D.'s Avatar
Originally Posted by bbyevo8u
yeah my car kinda does that too i wonder if my driveshaft is slowly going?
Now that I got the driveshaft in I'm hearing all sorts of other noises. It's too cold right now to bother looking under the car, but I'm hoping the bushings clear up those issues.
This is the AWD Motorsports driveshaft. Right away I noticed that when accelerating from a dead stop that the power delivery feels more positive, like there's less slack in the driveline and the entire system is more connected. It's not something you would ever notice with a car that's not falling apart, but once it's in there you realize how much of a difference it makes.
Old Feb 1, 2010 | 07:57 AM
Matt D.'s Avatar
Awesome. I do plan on getting all of the suspension bushings upgraded eventually. That was a plan for this summer, but instead I'm having to rebuild my head.
Old Feb 1, 2010 | 08:05 AM
bbyevo8u's Avatar
^^ what happened to your head?
Old Feb 1, 2010 | 08:11 AM
Matt D.'s Avatar
Exhaust valves decided they don't want to seal any longer.
https://www.evolutionm.net/forums/ev...ggestions.html
It never ends.
Old Feb 23, 2010 | 02:01 PM
LadyJDM's Avatar
tell me about it! my boyfriend's e30's driveline was horrible.
Originally Posted by eric06ix
E30 BMWs are notorious for killing that exact part. Hopefully it's just that coupler and nothing else.
Old Feb 23, 2010 | 08:53 PM
Still have a bunch of noise in the driveline?
