injectors sizes for e85???
Old Dec 19, 2009 | 07:56 PM
bluemonster2's Avatar
well everyone I am doing an e85 build over the winter. Looking to run about 600 hp. Going to be running a 5857 turbo with descent boost. Let me know what size injectors I will need to run this much power??? Thanks for the input.
Old Dec 20, 2009 | 07:06 AM
Mellon Racing's Avatar
1450cc will do the trick, you'll also want to do a twin walbro fuel pump kit like the one from Buschur Racing
Old Dec 20, 2009 | 09:20 AM
fre's Avatar
fre
If you can afford the extra $40/$50 or so, I would just get 1850s, why go smaller and give yourself less headroom? So you can buy another set later down the road?
Old Dec 20, 2009 | 09:22 AM
depending on the brand, some larger injectors run like crap or not at all when they require 16v
Old Dec 20, 2009 | 09:25 AM
fre's Avatar
fre
I was referring to the FIC bluemax. They do, however, recommend the box with it which is another $200 I believe, so price would be more like $600 or so instead of $400. I can't remember if they recommended the box for their 1650s or not.
Having said that, if he is running e85, they might be fine without the box.
I am just going with the $1000 2150s, which don't require a box, but I am tired of buying new fuel injectors.
Old Dec 20, 2009 | 09:26 AM
I'm running the 1650CC bluemax, not so hot on pump gas for idle/cruise very rough, but considerably better with e85. The car would not even start with the 1850cc
Old Dec 20, 2009 | 09:30 AM
fre's Avatar
fre
You try the truetune box or whatever they call it yet?
*edit* easytune. Also did you try the 1850s on gas or e85?
Old Dec 20, 2009 | 09:37 AM
no, the box was still in development at the time.
the 1850cc wouldn't even spray on a 14v system, the car wouldn't start, they are designed for 16v. I dropped down to the 1650cc. I'm seeing 90% IDC with 700awhp (DynoJet) on e85
Old Dec 20, 2009 | 09:42 AM
fre's Avatar
fre
Yea, with my inline fuel pump system (walbro in tank/bosche 044 inline), hard to say what that would be good for on 1650s. I have better flow at higher pressure, but not overall like the twin in tank systems. I doubt I will hit much higher than 600whp when I build my engine, but I like a lot of headroom for future upgrades.
I am maxed out right now on 1150s @ 530-540whp.
Old Dec 20, 2009 | 09:50 AM
If I had it to do over again I'd go with the ID2000cc injectors but they are pretty expensive. I might change to them eventually.
Old Dec 20, 2009 | 11:42 AM
KTriplett's Avatar
see my guess of 1600's was pretty good haha.
Old Dec 20, 2009 | 12:43 PM
italianevo88's Avatar
since were on the subject would anyone care to answer my question, im looking to change over to e85, and i have 750cc injectors, i really want to get around 400WHP, do they provide enough fuel?
Old Dec 20, 2009 | 12:47 PM
I think the 750's will be sufficient
Old Dec 20, 2009 | 01:13 PM
l2r99gst's Avatar
750s won't be sufficient to max out your stock turbo on E85. Doing some quick math, I come up with 828cc at 100% duty cycle needed to support 43lb/min airflow at a 11.5:1 gasoline calibrated AFR (.783 lambda).
You will be able to max out your stock turbo on E85, so your current 750s won't support it (at least at the .783 lambda/11.5:1).
The 750s on E85 and a maxed turbo would lean out to about 12.9:1 (gas calibrated).
Old Dec 20, 2009 | 04:26 PM
oh i forgot to add im not running stock its a precision 58mm, but that was some hardcore info thanks alot, would the 1000s be the way to go then?
