Exhaust install gone wrong
So my current set up is ebay O2 housing, 2.75" Apexi DP, custom cat, 3" Apexi cat back.
I went to change the DP because it was hitting the transfer case. I got a 3" megan DP and 3" megan test pipe.
The DP is like two inches shorter than the Apexi and now it will not line up. There is like a two inch gap.
What should I do. I purchased the DP from a member on here who said it was for evos with ACD, as I could see with the bends in it.
The custom cat and the TP are the same size, it is the DPs that are not the same.
I'm dumbfounded at how this happened. Any ideas.
