calling all forward facing manifolds
well the time has now come for me to up the bar on my evo. i have been looking into peicing a kit together. first off i parted out my turbo honda and have a t3 60-1 .63a/r i was going to use that just for now on a forward facing manifold. is this turbo going to be decent or should i sell it asap and 35r right away?? and is the exhasut side gunna be to small and run outa breath up top since i have a 2.3 stroker engine right now. 2nd? is which forward facing manifold seems to be the favorite for placment and fit??
sorry to ask an off topic question, but what addvantages are there to forward facing manifolds compeard to traditional ones?? The exhaust gas still has to turn through 2 90* bends. Can you fit a fillter on the intake side of the turbo? dont they force you to run a smaller rad??
Cheers
Chris.
Cheers
Chris.
Cheers
Chris.
Cheers
Chris.
Many people use ours with great results. However, it is very aggressive and will not fit a filter. Here are some pics of it installed on our car.
And some more can be found here
http://www.streettunedmotorsports.co...m_ricer_09.htm
This manifold has gone 9.6@156 so far (with a 6262) with some room left. In other words, IT works.
More info on it can be found here
http://www.streettunedmotorsports.co...evo_turbos.htm
Videos of our car in action with this kit are in my sig.
-Em
-Em
The forward facing manifold is really only an advantage to those looking to run open filter at the track to take advantage of air getting forced in the compressor as you go down the track. The bends are not an exact 90* because the turbo is tilted back just slightly. Some kits allow for a filter and some do not. If going for a kit, I would look at the Buschur as it looks to be the most complete. I see my self going down this road in the future after I string out the stock turbo on my 2.3.
not looking for somthing crazy just a nice 550-600awhp.
no one ever answered my first ? is a t3 with a .63 a/r gunna die off up top as well cuz if so ill ditch the 60-1 i have lieing around for something else. im trying to avoid boost falling off i want it to rip all the way through the rpm range
ya i have lookd at these manifold n like how they look/ perform! running a filter isnt a big deal to me i have been rockn no filter on turbod hondas for years without a problem and the evo is my daily so..... iv been leaning towards a stm manifold but just wanted other imput. after the holidays ill be maken a purchase n hope its a good decision.
Honestly, I'm going with a front facing turbo and I won't run a filter, I will just make a block off plate for when I do street drive it, which won't be much.
Really the only front facing turbo manifolds I have seen come from STM, Buschur, AWD, AFI, and the fab worx one.
-Em
-Em
i have another question for you guy using a civic rad. do you have any cooling issues at all cause i have a pwr civic rad im thinking about putting in my evo cause my stock rad is busted. one day i will for sure pick up a forward facing mani.
im using a civic radiator and its working fine...even in stop and go traffic (80 degree heat) it never got too hot...im using an aluminum shroud and a spal fan so im sure that helps make a difference...i was considering an electric water pump too but i havent had the need just yet
Nobody is mentioning Shearer or Fullrace?
Check out this thread.
https://www.evolutionm.net/forums/ev...-manifold.html
this one too.
https://www.evolutionm.net/forums/ev...rications.html
I like the look of the ETS manifold. A filter is good on a street car.
Fab up a holset HX35.
this one too.
