clutch/drivetrain help, cant get in gear
Old Dec 24, 2009 | 07:09 AM
psphinx81's Avatar
well i pulled my tranny and transfer case to put my built x-case in.. i pulled my clutch off as well while waiting for my transfer case to get back to inspect everything, put it all back together now i cant get my car in gear.
clutch im using is a quartermaster twin disk, only has 700 miles on it. everything worked perfect before i took it all apart.. DOH
i have my car on the lift now, e-brake on/off wont go in gear, but it makes some loud clunking if i try to put it in gear. the clutch is not disengaging for some reason. i tried adjusting my clutch pedal already, nada..
also while the car is up on the lift running, ebrake off, my wheels are spinning slightly while the car is idling car and in neutral.. i inspected all my shifter linkage etc. you name it i double checked! car goes into gear fine when the car is off, nice and smooth..
any insight here? what do you think the culprit is here..
Old Dec 24, 2009 | 12:41 PM
20gmr's Avatar
Try to put the car in gear with it off, then push the clutch in and have someone else try to rock the car.
You should be able to tell if its disengaging from that.
how does the clutch pedal feel when you push it in, are you confident its bled completely?
Old Dec 25, 2009 | 05:14 AM
psphinx81's Avatar
i know its not disengaging, push in the clutch pedal and i cant hear the clutch rattle with the QM..
pretty sure its bled completely, but i will try again and see how if it gets me anywhere
Old Dec 25, 2009 | 09:38 AM
justboosted02's Avatar
im not familiar with teh QM but are you sure you put the discs in correctly and one of them is not backwards?
Old Dec 25, 2009 | 09:42 AM
psphinx81's Avatar
yep, its on the same way it came off. i think its something with my TOB at this point after playing with it yesterday. im probably gonna have to pull my tranny again, farts!
Doctro X
Dec 10, 2016 10:35 AM
tsitalon1
29
Nov 19, 2015 05:30 PM
elijahcole92
17
Oct 19, 2009 11:46 AM
deuce329
May 10, 2009 06:00 PM
evo05VIII
13
Mar 6, 2009 03:47 PM
