Old DSM tricks?
Old Dec 25, 2009 | 08:17 AM
franc01's Avatar
Old DSM tricks?
Happy holidays!
I was reading Dave B's intercooler cleaning thread and it reminded me of those tricks we used to do to our DSMs back in the day. Does anyone have any others that could be applied to our Evos?
For example, I remember taking the shift cables off of my '90 Laser fwd-t's shifter base and adjusting them until the second gear grind disappeared. That simple mod lasted over 100k miles! I also remember rewiring my fuel pump with a relay and maybe 8 ga wire to boost the volts seen by the pump.
Safe driving!
-Franc
Old Dec 25, 2009 | 08:56 AM
JohnBradley's Avatar
Pump rewire is a good mod, the shifter cables aren't the same design.
Old Dec 28, 2009 | 08:51 PM
franc01's Avatar
I also remember bypassing the coolant lines going into the throttle body on my DSM.
Old Dec 28, 2009 | 08:56 PM
Kracka's Avatar
You can do that on your Evo too; I did.
Old Dec 29, 2009 | 05:55 AM
Steve93Talon's Avatar
If you bypass your coolant lines, you might get idle surge because the FIAV won't be able to function correctly. You'd also have to remove/block/eliminate the FIAV for the car to run right.
AngelPowy
Dec 4, 2015 01:48 PM
franc01
Jun 29, 2015 09:36 AM
franc01
May 15, 2015 03:58 PM
franc01
Apr 18, 2015 07:14 AM
franc01
11
Dec 25, 2009 04:10 PM
