Evoscan nb O2 front sensor voltage ?
Old Dec 27, 2009 | 11:25 AM
TJung's Avatar
nb O2 front sensor voltage - Evoscan screen inside
Hello. Did somebody knows, what is correct Evoscan voltage displays for nb O2 front sensor. I can't find it anywhere :/
Old Dec 27, 2009 | 11:27 AM
JohnBradley's Avatar
Tomas, you mean the value that you want at WOT or the scaling? It should be in the ECUflash forum, but the NB voltage is typically in the .917-.936 range.
aaron
Old Dec 27, 2009 | 11:30 AM
TJung's Avatar
Aaron, I was sent You email but I'm not sure You get it ?
I'm still fightin with my idles. It look like this sensor is dead (someone from this forum seen my log), but i'm not really sure. So that's why I need this value for idles.
Ofcourse I'm talking about Evo 9
Old Dec 27, 2009 | 01:47 PM
TJung's Avatar
bump
Old Dec 27, 2009 | 08:49 PM
Can you post up the log again? I got the email but didnt see a log attached. If you are getting no voltage at idle or "stuck" low where its .03395 or something like that I would say dead sensor. Is it cycling, that is moving between .19v and .97v on its own? Are the O2 feedback trims working?
Old Dec 28, 2009 | 05:31 AM
TJung's Avatar
Here is screen from my Evoscan:
Old Dec 28, 2009 | 02:38 PM
TJung's Avatar
This is very important for me anybody have some ideas ? Are my values correct ?
Old Dec 29, 2009 | 11:21 PM
TJung's Avatar
up
Old Dec 29, 2009 | 11:25 PM
GST Motorsports's Avatar
If the NB isn't cycling at normal operating temp it is most likely dead or problem with wiring
Old Dec 30, 2009 | 01:43 AM
TJung's Avatar
Thanks for answer. I guess, that my o2 sensor is working, because I've tested it with traditional voltmeter. The problem might be in wiring, because my car is sooo custom and ECU's not seeing this sensor: / I think I have a lot searchin to do with my spagetti...
jameswwt
Jun 18, 2012 02:23 PM
jameswwt
Apr 30, 2012 09:45 AM
eboru-shon_x
Feb 8, 2011 10:04 PM
TJung
Jan 4, 2010 08:09 AM
racer135
Jul 18, 2008 06:42 AM
