anybody have a how to for "bosch 044"?
What your going to want to do (or what i would do) is use a relay and use stock fuel pump wiring as trigger for the 044. If i can find a diagram of how the stock wiring is setup when i get home ill give more detail.
You want to use a relay that uses a positive trigger for the coil. The coil trigger is the +12v that went to the stock fuel pump, the other side of the coil is GND. Then you want 10AWG POSITIVE in, and 10AWG POSITIVE out to the new fuel pump. Make sure the pump has a good ground.
Napa part: AR272
30: 12V 10AWG power in
85: 12v positive trigger from old fuel pump
86: GND
87:12V 10AWG power out
Napa part: AR272
86: GND
Stock ECU?
If so then,
85: will be a NEG trigger such as a hobbs switch
86: will be 12v
Make sure all +12V sources have an applicable fuse.
If so then,
86: will be 12v
Boostin Perform
11
Sep 26, 2016 09:42 AM
jessmanEVO
Mar 2, 2012 10:32 PM
Stealthmatt
E85 / Ethanol
May 7, 2011 07:02 PM
justa4banger
90
Jan 16, 2010 03:55 PM
