soon to put on the FP Red 80mm...
Just proving that the opinions of others are incorrect - and you are not limited to 420 or what ever they are trying to claim. David will have no problem extracting 450+ whp from your car on his dyno.
But as I said before - you are going to need the 65mm TB. If you dont make the power -- I would likely point a finger at the brian crower cams. They have proven to be a ... hot mess... when it comes to performace.
I had Comp 280s in my car before Buschur cams. They worked very well for me. I picked up 25 whp over HKS 264/272 (on the dyno). DLL indicated that after I got my Red (64mm, not the 80mm) I was making 460 whp on pump at 25 psi on the stock motor. When Mel lon ran the numbers through DLL he got an even higher number than I did.
just a disagreement, I do agree on the BC cams, have not seen many good results with those.
On the other hand, the Comps from all the posts I've read made good power, I have a set on mine too. Just like EVO8LTW there have been a few results showing the Comps beat out the HKS's for power, making them a great all around cam especially on a budget.. got mine for 440 a few years ago. I definitely would not call them crap. Nowadays of course, one can pick up a set of FP4R's or the like and make even more power, they didn't have cams like that when i got my Comps... if anything I'd just say the Comp's design is outdated now. Still make good power though.
But on topic, +1 on going with something else to the OP... yet to see an impressive BCrower dyno sheet
damn what was I thinking
