soon to put on the FP Red 80mm...
Old Jan 4, 2010 | 07:38 AM
Darkn3s's Avatar
hey guys well in this off season im going to be putting in my Fp red 80mm/ buschur ported in the 03 evo 8. what do u guys think im going to be making as in power. or what are your guys thoughts as in what i should change, keep or add. thanks
i have all the supplies i THINK i need already: (not installed yet)
-Fp red 80mm/ buschur ported
-fp upgraded oil lines w/ new gaskets/ race pipe
-buschur ported stock exhaust manifold
-jmfab o2 dump
-precision 1000cc injectors
-walboro 255 fuel pump
and this is what the car has of right now (made 415hp/401trq with this setup)
-evo9 turbo
-megan tubular manifold
-megan o2 housing
-megan downpipe w/ cutout
-qtp electric cutout
-hks hi power cat back
-ACT HDSS clutch about 3k in miles
-fresh tranny rebuild with 800 miles or so
-ams licp
-ams fmic
-buschur uicp
-tial bov
-buschur ported intake manifold
-bc 272s
-aquamist hfs-5 (tuned 100% alcohol)
-ecuFlash
-aem uego
Old Jan 4, 2010 | 07:43 AM
xRoguex's Avatar
With similar mods - without meth - I made 400 on the BR dyno with zero timing. My motor was slowly spinning bearings.
David expected closer to 440 on his dyno.
Do you have a 65mm throttle body?
Old Jan 4, 2010 | 08:01 AM
IDRINKV8'S's Avatar
Nice looking setup...I made 500 whp with no cams,intercooler pipes,or any porting on 30 psi easy......also with three boost leaks...
Old Jan 4, 2010 | 08:02 AM
xRoguex's Avatar
^^^ your also a mivec
Old Jan 4, 2010 | 08:05 AM
IDRINKV8'S's Avatar
good point did see his sig..But if he puts cams then he's good to roll.
Old Jan 4, 2010 | 08:08 AM
xRoguex's Avatar
and - my readings were on a mustang.. what was yours on?
Old Jan 4, 2010 | 08:10 AM
FL_SilverEvo8's Avatar
might want to change that clutch. ACT's are known for lock outs and stuff
Old Jan 4, 2010 | 09:15 AM
Darkn3s's Avatar
oh i was on a dyno dynamics dyno.. on 27psi
and no i have stock tb.. any suggestions on which tb i should go with or if it even matters?
Old Jan 4, 2010 | 10:54 AM
tscompusa2's Avatar
i agree get a exedy twin hd ... act isnt so hot for the evo world.
Old Jan 4, 2010 | 10:57 AM
compscibOi's Avatar
+1 very soon after my upgrade to the same turbo, the ACT just died a fast death. I went Exedy twin.
What type of fuel? I don't see any cams on your list?
Old Jan 4, 2010 | 10:58 AM
Svendiesel's Avatar
Cant really go wrong with any of the TB's. Id go with a Milspec because it comes with the hi-pressure shaft seals which actually do work. One less future boost leak to worry about.
Old Jan 4, 2010 | 11:17 AM
Darkn3s's Avatar
i wrote brain crower cams and gears
yea im looking into the clutches/ flywheels trust me and throw in a shep tc while im at but hoping if it happens its later on hehe
Old Jan 4, 2010 | 11:53 AM
BLKCarbonEVO's Avatar
^ you may break 500 on a DJ. Look at my sig for my mods.
Mikey
Old Jan 4, 2010 | 12:35 PM
Darkn3s's Avatar
Mikey
hmm pretty similar to mines except for the fuel rail lol should i get one is it necessary? and do u have a external wastegate setup or fpr?
Old Jan 4, 2010 | 12:41 PM
o-townFLA's Avatar
I've road raced my ACT for 2 yrs and didnt have a single problem ever shifting at full WOT on the FP Red and at high rpm's...
Mil.Spec makes a killer 65mm TB but you'll have to port out your IM so they match...
And it looks like your goin to have a killer set-up when all is said and done...
