Exedy twin owners only please!!!!
Old Jan 4, 2010 | 06:51 PM
C130flyer's Avatar
Did your clutch pedal vibrate at all, after you installed this clutch.
When I depress the clutch pedal I feel an rpm connected vibration until fully released.
Do any of you have the same issue? If it isn't normal whats causing it?
Your thoughts please Gentlemen....
Old Jan 4, 2010 | 06:56 PM
ch53avitech's Avatar
I have the Exedy HD and I don't feel any vibrations in the clutch pedal.
How does the clutch perform, minus the vibrations?
Old Jan 4, 2010 | 07:01 PM
justboosted02's Avatar
mine has no noticeable vibration
Old Jan 4, 2010 | 07:48 PM
C130flyer's Avatar
it performs perfectly just a little more vibe than normal, but only when I am pushing in the pedal before it is fully disengaged.
Old Jan 4, 2010 | 07:51 PM
tscompusa2's Avatar
I don't remember mine ever vibrating either. you didn't accidently put the clutch disc in the wrong order did you? The only thing I can complain about for the exedy twin is it makes some wierd *** noises sometimes. it howl's and does all kinds of **** when downshifting very nice clutch though for a daily driver with mid/high hp.
you should put car on jackstands and follow TRE's clutch adjustment procedure. http://www.teamrip.com/clutch_pedal_...ment_info.html
Old Jan 4, 2010 | 07:55 PM
tim85851's Avatar
i have the cusco twin which is just the exedy twin with a blue pressure plate instead of purple...no vibrations...had mine installed at mitsubishi and its been trouble free for me...
Old Jan 4, 2010 | 08:08 PM
Liqquid's Avatar
no vibrations on mine, +1 on double checking pedal adjustment
You could try bleeding the clutch.
I'd start by checking the pedal adjustment. Then I'd inspect slave cylinder and clutch lines for anything out of the norm. Sorta sounds like a mechanical malfunction of some sort. On second though, maybe the release bearing?
Who did the install?
Old Jan 4, 2010 | 08:09 PM
buchnerj's Avatar
No vibrations in mine either. +1 to bleeding the clutch. Sure you aligned it right?
Other than the vibrations, how does it feel?
Good luck
Old Jan 4, 2010 | 08:10 PM
Liqquid's Avatar
this too... make sure it is completely bled and can fully disengage
Old Jan 4, 2010 | 08:19 PM
Boltz.'s Avatar
FCOTM Winner
Warning: This post may be completely useless.
I have the exedy twin and do not have the problem you are experiencing. Although I am having a brain fart and can't come up with what I think I have to say, I recall someone having a big problem with their clutch which was forewarned by the same symptom you have. Because I can't figure out exactly what it was that I read, you should probably take this with a grain of salt and ignore me, but I would spend a good amount of time searching on here and see what you come up with....
Hey, I warned you! Hah. GOOD LUCK!
Old Jan 4, 2010 | 08:21 PM
Boltz.'s Avatar
FCOTM Winner
On another note, I would say that this has to do with a mechanical alignment, orientation or balance issue. I would put zero marbles in the fact that it could be cured with a bleeding or a pedal adjustment, although when tracking down a problem, you always do the easy stuff first.
Old Jan 5, 2010 | 04:05 PM
C130flyer's Avatar
I never broke open any clutch lines during the install so its not a bleed issue.
It went away so IDK what it was oh well its gone I'm happy now LOL
Thanks for posting all.
Old Jan 6, 2010 | 09:44 AM
luckybull's Avatar
Mine does it. i notice it if i put my foot on the clutch while driving, or right before pressing the clutch it..
its not terribly noticable, but i do feel it..
i also notice the engagement point changes all the time! ANNOYING! im gonna do the team RIP adjustment
Old Jan 6, 2010 | 09:55 AM
1d10t's Avatar
Was this new or rebuilt? Wondering if there may have been machining or something causing a clearance issue and slight drag?
