EVO 8 Axel shaft and tips
Old Jan 8, 2010 | 06:47 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Got your PM sorry I have been ultra busy. Ok so first thing is your not going to need axles or rear diff upgrade. Suggestion would be to change your fluids in your tranny, TC, and rear diff to something like Amsoil....and makes ure you change it every 15k. You will not snap the axles with 400hp. The only way I could see that happening is if you were to dump the clutch and I assume your TC would go first before the axles.
Next lets tackle these mods. 1k injectors seem big almost too big. Are you planning on going with a FP red or Black in the near future? If not then 1k is too big.
What turbo are you using to attain your goal of 400hp?
Old Jan 8, 2010 | 08:00 AM
Ev0ikon's Avatar
Originally Posted by Jimbolution
(sorry im french canadian )
I am sorry for you too.
when your said rebuilt, you mean upgrade?
You should always upgrade to stronger parts if you are making more than stock power. Make sense, yes?
And if you are just making 400HP then don't worry about the axles. They are very strong.
Old Jan 8, 2010 | 08:41 AM
Jimbolution's Avatar
not this year for a bigger turbo, so i will stay with the stock one...
Old Jan 8, 2010 | 11:22 AM
DBallz's Avatar
I don't want to be Buzz Killington but I don't think your going to make that much HP with the 03-04 turbo 9.8 hotside turbos didn't make that much hp....if you had the 9 turbo then yes I could see it being done and then you would need the injectors. If your not going to upgrade the turbo then injectors are just over kill.
Old Jan 8, 2010 | 11:37 AM
Lancerguy'03's Avatar
reading your 1st post.......your next mod should be some cams....like Kelford 272 and springs/retainers. that will give the most improvement and can be used for any other mods you plan to do...
Also get a lower intercooler pipe, and 02 pipe....you have a lot to do before you can get to 400hp....
look at my mod list and im makeing 400/400 at 32psi.....
Old Jan 8, 2010 | 12:12 PM
but even if i don't put a bigger turbo this year, i can put the injector? or it will be bad for the car ? or maybe put like 880cc ? or keep the stock one until i put a bigger turbo ?
Old Jan 8, 2010 | 12:53 PM
Ev0ikon's Avatar
Unless you have ways to tune, adding those injectors will make it run rich = power lost = more carbon buildup = bad for sex... err sooth..
Old Jan 8, 2010 | 01:00 PM
so i stay with the stock one that support unless 400hp or bigger turbo right ?
Old Jan 8, 2010 | 01:01 PM
if i don't buy these, which part will be fine... an ETS 3.5" IC Kit ?
Old Jan 8, 2010 | 01:19 PM
did you read what i posted??
Old Jan 8, 2010 | 02:05 PM
TxEvo8's Avatar
some people just can't be helped...
Old Jan 8, 2010 | 02:23 PM
zedevo's Avatar
Go for Buschur Parts ... Like BF Cams 272 with Beehive Springs , FMIC Piping , Shearer Headers ,
Good Luck ...
Old Jan 8, 2010 | 02:45 PM
ch53avitech's Avatar
Good Luck ...
That's a good idea. Buschur Racing's staged upgrades are fool proof. With all of the upgrades your set up for success.
So easy, even a caveman can do it.
Old Jan 8, 2010 | 02:57 PM
cams ?!?! there a lot of possibilities... but is recommended 272 / 264 or two 272 ?!?!
im not sure between the GS series, kelford and HKS... there seem all good but if i buy cam, i need cam gear and cover ?
Old Jan 8, 2010 | 03:04 PM
zedevo's Avatar
HKS are Baby Cams ... I have 272 on my VII ... and 90% of my parts are from Buschur Racing ... Awesome service and follow up ...
Contact Jarrod or David ,
