Well I blew the motor (pics inside)
Old Jan 6, 2010 | 03:31 PM
mugen777's Avatar
Happened at about 8300 rpm in 4th gear, looks like she went lean and egt's went through the roof, these are wiseco HD pistons. This was the number 4 piston...
The result was a melted piston
Old Jan 6, 2010 | 03:33 PM
scorke's Avatar
How lean did it get?
Fuel and boost level?
Sorry man, looks like that piston was looking for a way out the kitchen and came up short...
Scorke
Old Jan 6, 2010 | 03:35 PM
mx4life85's Avatar
Sorry to hear this....
Hopefully you will get her running better/stronger than before!
Old Jan 6, 2010 | 03:36 PM
Evoryder's Avatar
Faulty pump? Injector? Maybe weather related....good luck on the build.
Old Jan 6, 2010 | 03:37 PM
mugen777's Avatar
Scorke
Yeah it sucks man, I was on straight pump gas (93) boost was 29-30psi. The wideband is built into my AEM. I don't have a gauge at the moment, which was completely my fault.
**** happens, though this probably could have been prevented if I had the actual gauge and caught it in time.
mugen777's Avatar
Could have been, it was on a cold night its been in the twenty's and teens down here.
Old Jan 6, 2010 | 03:38 PM
mugen777's Avatar
Thanks man, yeah at least I have a built to look forward too
Old Jan 6, 2010 | 03:41 PM
scorke's Avatar
Any other signs of excessive heat on the head or other pistons?
All the other exhaust valves are ok?
Do you know what sort of airfuels you were targetting?
First time doing these sorts of boost levels and RPMs or was this regular usage with irregular outcome?
INTERESTED!
Scorke
Old Jan 6, 2010 | 03:49 PM
mugen777's Avatar
INTERESTED!
Scorke
The other pistons actually looked fine, the afr's I was targeting were 11.2 mid range to 10.9 at redline.
Yes this was very regular with a irregular outcome, I really wonder if an injector failed. I need to test them..
Old Jan 6, 2010 | 04:35 PM
kouzman's Avatar
yes, check the injectors man. I am really curious to see what happened!
The piston looks completely melted! Whats the melting point of forged aluminum? Thats crazy!
Old Jan 6, 2010 | 04:39 PM
binh's Avatar
at least the piston didn't break apart and create an ugly mess....
Old Jan 6, 2010 | 04:47 PM
ch53avitech's Avatar
At least the block still looks good. Might have to be bored though.
Old Jan 6, 2010 | 04:52 PM
oneofakindracer's Avatar
o nooo im sorry man keep your head up and build an even better beast
Old Jan 6, 2010 | 05:09 PM
mugen777's Avatar
Yeah I gotta look on the positive side, the block is still good. I will deff have it bored I am hoping .20 over will get it.
Old Jan 6, 2010 | 05:14 PM
Boosted Tuning's Avatar
That sucks. GL on the rebuild and finding the cause. Like everyone else is saying, least the block looks usable.
