156mm Carillo H-beam: Custom or Available?
Old Jan 10, 2010 | 05:06 PM
R/TErnie's Avatar
is the 156mm Carillo H-beam rod a custom connecting rod or is it something that is stocked at some shops?
I looked on Carillo's site and I only saw the 150mm rod listed.
The reason I ask is... if 156 is a custom rod length... and I have to buy a custom piston anyway... then I guess I can run a slightly longer rod to help the r/s ratio.
Thanks in advance.
Old Jan 10, 2010 | 05:08 PM
n2oiroc's Avatar
im also wondering who makes custom length steel rods.
Old Jan 10, 2010 | 05:10 PM
JohnBradley's Avatar
R&R will make pretty much any length you want and use either ARP2000 or Custom Age 625 rod bolts.
Old Jan 10, 2010 | 05:21 PM
R/TErnie's Avatar
JB do you know the weight of a 150mm R&R Evo rod?
Old Jan 10, 2010 | 05:28 PM
CO_VR4's Avatar
pauter, manley
Old Jan 10, 2010 | 05:36 PM
R/TErnie's Avatar
Bah you guys.
is the carillo 156mm rod a custom rod or a standard available rod?
Old Jan 10, 2010 | 06:45 PM
94AWDcoupe's Avatar
you should be asking who makes a 156mm rod.
manley I beam, magnus are your two choices.
the others would be custom order 6 week wait BS.
Old Jan 10, 2010 | 07:40 PM
Ted B's Avatar
My 156mm are Olivers. I had to wait, but it didn't take too long.
But of course, if you're really concerned about weight, Oliver can make a set from 6AL4V Ti, and those weigh in at around 400g. ($$)
Old Jan 10, 2010 | 09:16 PM
Magnus' rods are made by R&R and are generally on the shelf. K1 has 162mm but I havent been able to find a 156mm part number.
Old Jan 10, 2010 | 09:18 PM
Teal2nnr's Avatar
^^ Wouldn't even want to know the price of that 3k+ i would imagine (the Ti that is)...
Old Jan 10, 2010 | 09:40 PM
R/TErnie's Avatar
Ted what is the price of the Ti rods? If I'm looking at 1k for the carrillos to save a few grams... I wonder how much more it is to save a hundred plus grams.... then I might as well get some aluminum rods. slippery slope!
Old Jan 11, 2010 | 06:11 AM
Ted B's Avatar
A good friend of mine has a strong rapport with Oliver. Let me see what kind of price I can get.
Old Jan 11, 2010 | 07:08 AM
R/TErnie's Avatar
Thank you Ted. I appreciate it!
Old Jan 11, 2010 | 05:18 PM
R/TErnie's Avatar
I found some information out that I posted in my other thread that I'd post here since I feel it's relevant
Well I called Carrillo today and I called R&R…
Carrillo H-beam 150mm is 567grams(TOTAL) 396grams(BE) 171grams(PE)
Actual weight of the Carrillo @ 574grams (measured by Kouzman)
Price: 1312.00 w/CARR bolts @ 6weeks
The 156mm Carrillo rod is a custom unit...not stocked.
R&R H-beam 150mm is 571-575grams(TOTAL) 403grams (BE) 172grams(PE)
Actual weight of the R&R as measured by Mike on the last set that was shipped @ 571 grams
Price: 1012.00 w/625 custom aged bolts @ 6weeks
The R&R A-Beam 150mm is 612grams(TOTAL) 415 (BE) and 197(PE)
Price: 860.00
R&R H beam has a strong case. I focused most of my attention to the PE (wrist Pin End) weights more than the (BE) weights (standing for Big End) and the overall weight (which is the first step)
2006GSR
Feb 5, 2017 07:08 AM
TitanMotorsport
Jan 18, 2017 01:41 PM
SBR INC
Nov 26, 2016 07:39 AM
MRadjahoe
May 7, 2016 01:01 AM
4g63tgt35r
Feb 21, 2016 06:27 AM
