MIVEC / Big Cams -> Static Compression?
Old Jan 11, 2010 | 01:28 PM
JohnnyTSi's Avatar
I've read in other posts that a stock ix will read somewhere about 140psi on a static compression test!
What about when big cams are added to the mix?
I'm trying to figure out what would be "normal" for a MIVEC engine running S2 cams.
Thanks,
John-
Old Jan 11, 2010 | 06:23 PM
biggie5252's Avatar
My compression is still about 135-140 with M2 cams.
Old Jan 11, 2010 | 06:28 PM
JohnBradley's Avatar
Biggie, I would assume you are still a 2.0L block?
Old Jan 12, 2010 | 05:00 PM
Tonba's Avatar
Mivec shouldnt change static compression, only affecting dynamic compression.
Old Jan 12, 2010 | 06:21 PM
When its cranking there isnt enough oil pressure to force it to "0" though so it will change vs an VIII.
It shouldnt be much different but we have a tall deck block with the cam gear slightly off and make up for it with the MIVEC. However The thread should be titled perhaps, "What is 1/2tooth off cranking compression with S2s"?
Old Jan 14, 2010 | 07:54 AM
biggie5252's Avatar
Yes. 2.0l. (stock bottom end)
Sheasta
Jun 20, 2016 12:38 PM
QuickIX
18
Jun 22, 2015 07:08 AM
manthny18
Jun 18, 2015 10:25 AM
HybridKOOP
27
Jul 9, 2010 07:36 AM
EVIL_EVO_VIII
Jul 8, 2005 02:29 AM
