what can this motor rev to?
Old Jan 16, 2010 | 03:00 PM
opie's Avatar
It's an eagle 94mm crank, 150mm rods (stock rod length), custom spec'd
weisco pistons (similar to the 2.3 stroker pistons but with the wrist
pin moved down 3mm for a compression height of 31.7mm. pistons
were built for 9:1 it also has the ams race balance shaft Eliminator Kit.
tomei 280 cams ams cnc head
its a 2.2 lt
Old Jan 16, 2010 | 03:01 PM
_mcjonnyp's Avatar
what's done to the head?
Old Jan 16, 2010 | 03:04 PM
opie's Avatar
ams cnc head
Old Jan 16, 2010 | 05:52 PM
turbodav's Avatar
rev limit 9,000 done
hurry up and get home so you can get this thing running
Old Jan 17, 2010 | 10:00 AM
opie's Avatar
come on someone has to have an idea.
Old Jan 17, 2010 | 12:10 PM
Teal2nnr's Avatar
Well are you taking DD rev limit? racing Rev limit? or the rev limit before everything explodes into fine dust?? Safe limit 7800 rpm (i would guess)
Old Jan 17, 2010 | 12:13 PM
brokeazzlos's Avatar
eagle cranks are known to break, I wouldnt rev it too high.
Old Jan 17, 2010 | 12:16 PM
fre's Avatar
fre
It sounds as though the rod ratio is slightly better than a 2.3 but still worse than a 2.0 so I would give it 8200rpm or so max. If you want to be safe for every day 8k would be conservative enough. If your going for broke and racing it, then 8500 might be an acceptable limit.
Old Jan 21, 2010 | 02:30 PM
opie's Avatar
thanks everyone for the info
Old Jan 21, 2010 | 03:16 PM
JohnBradley's Avatar
Since when?
To answer your question the rod stroke ratio is still 1.597 which will be good for low 9k. This combo seems to peak out at 7900 or so anyway with a big turbo (3586 and Magnus) so anymore than that isnt really needed. Look at my build thread in my sig.
Aaron
Old Jan 21, 2010 | 03:39 PM
opie's Avatar
thanks john
Old Jan 21, 2010 | 09:48 PM
dambikeracer's Avatar
Dyno it, find the peak HP, shift there. Set the rev limit at 8500-9000 RPM. Mine is set at 9k for 4th gear run out at the strip. Thats stock block and head. I shift around 7800-8000 with the Red.
Old Jan 22, 2010 | 01:03 AM
EvolutinIX's Avatar
Man those are impressive numbers at that elevation11!
Old Jan 22, 2010 | 03:37 PM
Thanks
Alexevo09
May 5, 2016 02:16 AM
nikush
Apr 24, 2016 03:20 PM
jameswwt
55
Dec 17, 2015 01:06 AM
danameisoj
Jun 22, 2015 08:36 AM
nesty2
10
Aug 30, 2014 09:47 AM
