What size injectors should I go with?
Old Oct 28, 2003 | 11:15 PM
Fourdoor's Avatar
If I was going for 500 to 550 wheel HP (590 to 650 crank HP) on pump gas with all supporting mods needed what size injectors would I need? My "best guess" is 880 cc but I havn't seen anyone specify what injectors to run for this HP level.
Thanks,
Keith
Old Oct 29, 2003 | 07:54 AM
8th_Sin's Avatar
Wow that is a pretty big goal to try and achieve on pump gas.
You may want to do a little more research on that one. Not trying to flame or anything but man, 500-550 whp is going to take a BOAT LOAD of mods.
Old Oct 29, 2003 | 08:50 AM
David Buschur's Avatar
I don't think you are going to see that HP to the wheels on pump gas. The knock threshold of the fuel is going to limit you.
To make that much WHP though you would be safe using the 880 cc injectors. You probably won't need over a 660 cc injector though.
David Buschur
www.buschurracing.com
Old Oct 29, 2003 | 11:53 AM
propellerhead's Avatar
David,
Help a newbie out...
What parameters are you using to come up with a 660cc injector?
According AEM's guidelines, using a BSFC of .65lbs/hp and a target of 400HP, I come up with 630cc (~725cc @ 85% duty cycle).
In your experience with these motors, what is an appropriate BSFC and duty cycle safety margin? Are injectors rated at 100% of duty cycle?
Old Oct 29, 2003 | 11:59 AM
MP5's Avatar
MP5
In Timeout
Originally posted by propellerhead
David,
This is were the tricks of the trade come in such as upping FP, higher octane gas, or going static for short periods. You loose control at 100% its just dependant on the pump at that point before it leans out
Michael.Keith
Oct 22, 2013 05:01 AM
Michael.Keith
Oct 15, 2013 04:21 PM
keith.
Oct 31, 2012 07:46 PM
Fourdoor
16
Jun 3, 2010 05:11 AM
Fourdoor
AEM EMS
Mar 28, 2004 09:28 PM
