oil catch can
Old Jan 28, 2010 | 06:45 AM
travail's Avatar
oil catch can
What is the best way to install one.
like this
Old Jan 28, 2010 | 07:34 AM
SpoolinUp's Avatar
Silver Sponsor
Only if you want to pressurize the valve cover.
Use the other port that is crossed off (remove PCV and replace with 1/8" BSP fitting). Block off far left fitting.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jan 28, 2010 | 07:45 AM
travail's Avatar
so like this then
here's the one that I got
Old Jan 28, 2010 | 09:09 AM
SpoolinUp's Avatar
Silver Sponsor
Is that one inlet and one outlet?
__________________
Old Jan 28, 2010 | 09:12 AM
travail's Avatar
yes
Old Jan 28, 2010 | 09:17 AM
yellowevo82's Avatar
ehh not the best catch can .. that looks like the ebay one.. here is the better choice..
http://www.jmfabrications.com/site/c...36b525fe56.jpg
Old Jan 28, 2010 | 09:19 AM
EvolNinja's Avatar
So which way is the right way?
Old Jan 28, 2010 | 09:25 AM
SpoolinUp's Avatar
Silver Sponsor
This way will work for a single input single output. No loss in metered air. You could add a second to catch the PCV air/oil. Only issue here is that you'd want to run the can behind the PCV so the can does not get pressurized by the intake manifold.
For the JMF one, you'd block off the PCV hole on the intake manifold and run both valve cover vent holes to the catch can. All of the gas would be vented to the air. The oil would be caught in the can. A bit of metered air would be lost.
__________________
Old Jan 28, 2010 | 07:35 PM
still*boostn's Avatar
like this
i have never been a d!ck on here but i gotta say this,....
LMAO
k sorry, but no dude, thats the right way on how NOT to do it. , sorry
Old Jan 29, 2010 | 05:11 AM
travail's Avatar
LMAO
That's ok I have never put one on before.
Old Jan 29, 2010 | 05:20 AM
apex electric's Avatar
A larger pipe is required to breath without restriction
Old Jan 29, 2010 | 05:33 AM
Gordian79's Avatar
I run the saikou michi functional catch cans with MA performance crank vents.when you run breather type catch cans your letting metered air escape causing driveabilty issues.
http://www.saikoumichi.com/OCC_explanation.htm
nikkadanny
Oct 2, 2010 03:40 PM
antevo7
Jun 23, 2010 09:12 AM
travail
18
Jan 27, 2010 03:35 PM
bdmaxima
Oct 17, 2009 07:44 AM
RED_DRAGON
Jun 4, 2009 10:28 AM
