Stock bov started to flutter
Old Feb 1, 2010 | 12:17 PM
06-EVO-9-MR's Avatar
When I take my foot of the gas at lower rmp's it will make a fluttering noise and jerk the car a little. I first noticed it after I got an upgraded intercooler put on. Is this okay or do I need to do something about it? It does get Anoying....
Old Feb 1, 2010 | 03:56 PM
boostin350z's Avatar
try loosening it up as just read on a similar situation.
Old Feb 1, 2010 | 03:59 PM
Loosen what up? The bov it self?
Old Feb 1, 2010 | 08:38 PM
BBS's Avatar
BBS
Who installed the intercooler? My primary intuition says that they reinstalled the diverter valve incorrectly which is a common mistake.
Old Feb 1, 2010 | 09:01 PM
09Ralli's Avatar
Mine does this sometimes also only at low low rpms
Old Feb 1, 2010 | 09:47 PM
fromWRXtoEVO's Avatar
Loosening what up? Can you elaborate?
Carlos
Old Feb 1, 2010 | 10:20 PM
hazdaddy's Avatar
mine does that too. it is quite annoying. i have a stock fmic though, so im guessing it must be on the wrong way?
Old Feb 2, 2010 | 11:16 AM
Carlos
here seems to be a similar situation and your answer
https://www.evolutionm.net/forums/ev...s-already.html
Old Feb 2, 2010 | 01:26 PM
k2evo's Avatar
+1
Check the DV. The bottom port should be on the UICP.
Old Feb 3, 2010 | 09:59 AM
The dv is fine and was never touched during the install. Any other possibilities?
Old Feb 3, 2010 | 10:17 AM
this is the correct orientation right?
Old Feb 3, 2010 | 10:38 AM
DJ Brett B's Avatar
^ yes
Old Feb 3, 2010 | 11:55 AM
boostedwrx's Avatar
Maybe run a new 1/4" vacuum line from the bov to the intake manifold, bypassing the small 5/16 oem line. Just something to try.
Old Feb 4, 2010 | 08:42 AM
DIDYSIS's Avatar
They are going to flutter a little, I kinda like it, but if you are trying to hold boost and they do it sucks, You can always get an aftermarket one, but really the Stock BOV, is great. I have had about 6 Bov's, stock one has about 11,000 miles, Greddy Type S Great sounds great mostly more flutter, HKS works great, sounds good, FRL, little crazy, does not hold well at boost, just had it for the sounds and weekend entertainment, I cant remember some of the others, but right now I use the Tial Q and I will not and can not complain at all about it. I love this BOV, and wish I would have got one right off the bat. Sounds good, holds boost, works great for light throttle, full throttle, no flutter at highway going up hills. never a problem at all. I am the happiest with this BOV and I will say it, THAT TIAL BOV IS THE BEST
Old Feb 4, 2010 | 08:43 AM
DIDYSIS's Avatar
Also I heard upgrading the intake pipe can make them flutter a little more.
