new FP green 73hta and old green compare pics
I dont see the fire. Looks like a nice pleasant discussion to me.
I havent had the pleasure of inspecting any of the BBK turbos. So everything that comes from me is complete bench racing. But for the most part compressor flow is simply a function of blade area. More area = more flow. From the dimensions of BBK it falls between the old and new green. There is no good info available on the new BBK. except they rate it at 58lb turbo. We dont really know where the red is. its been rated at 56-60 by FP themselves. Then we dont know how accurate the 58 for new BBK is either. with The BBK at 50 and the new at 58 is should be making more than 30 more that it made over the old.
So more flow = more power???? Most likely more lag too in a 2.0 L engine. Effificiency (compressed air temperature) has to play a role too. I am sure two turbos flowing 41 lb/min will not necessarily produce the same power.
I am flowing 41 lb/min on my 20G and only making 350 awhp on a dynojet. Timing is preety much max out without inducing knock. A more efficient turbo (i.e HTA or BBK) should make more power at the same flow rate. Right?
Don't both the HTA73 and the 80mm Red have larger cast compressor housings?
The BBK and BBK-B both use the OEM housing.
Am I correct in that statement?
If so, wouldn't the larger compressor non OEM housing allow these turbo's to make more power?
And if so, wouldn't their designation as stock framed turbos be removed since it wouldn't be the case anymore?
-Jalal
-Jalal
"This unit features the 54lb/min 73mm HTA compressor wheel and a new 65mm revision of the high efficiency 67mm turbine wheel used in the FP Red™ for the perfect combination of power and rapid spool."
Dyno chart from FP's website 2.3L motor with 4R cams and run in 3rd gear on 93 octane gas @ 24psi
It is also my understanding that most "stock frame" or "stock appearing" turbos do use the same stock configuration and/or compressor housing, however some sizes of it can vary. To me "stock frame" means that it is mostly similar appearing, and it will also use the same setup (i.e. exhaust manifold and intake locations) so it can bolt straight in. At least that is what I have learned.
What turbos are you interested in?
I have had most everything in my hands up to 35r size turbos. anything over that kills the fun factor on these cars. I collect all the data for myself. shops dont seem to be interested. They just bolt them on and see what they do.
first tests of the gtpumps HTA green73 with 10.8 hotside and unknown turbine are a little disappointing, 27psi is reached at 5krpm and max power was 265kw,98 RON dropping to 23psi, bbkfull on same dyno made 280kw @24psi 100RON, holding boost flatline, full spool was earlier on bbk and it outpowered it too. Maybe the turbine wheel makes all the difference?
