new FP green 73hta and old green compare pics
Old Feb 13, 2010 | 10:24 PM
  #46
buchnerj's Avatar
Originally Posted by burnzy
yeah heres the graph here.
heres the bbk graph
I was a bit disappointed as the turbo showed promise.
variance in fuel is because they're two different cars?
Two different cars? Same modifications? You really can't compare the two unless you use the exact same setup on the same car, and just swap turbines out. Then you can see the difference. When you have two different cars with different wear, parts, etc. you are changing too many variables other than the turbo.
I can personally say that I made 398 hp and ~390 torque (~297 kW) on a Mustang dyno on just 93 octane with my car a few months ago (over a few pulls). That car doesn't really seem to be pushing the turbo at all... especially with practically 100 octane race gas in the tank. It should be putting out well over 400 hp.
Old Feb 13, 2010 | 11:05 PM
  #47
burnzy's Avatar
our dynos (dyno dynamics) read alot lower here, plus, this HTA has a different turbine to the one FP sells.
similar mods except one is evo 8 and one 9, either way, I would have expected more topend from the HTA turbo. Just handing out results, make up your own conclusions.
surprised the HTA is dipping so much boost when it's running a 1.5 bar actuator too.
The dyno sheet was in fact posted by the seller of the turbo's himself (gtpumps) so I doubt he would have posted it had he felt it was an unfair representation of his turbo.
Old Feb 13, 2010 | 11:13 PM
  #48
buchnerj's Avatar
Oh, I understand now. I apologize. I thought you were showing that graph as a representation of what the FP Green HTA could put down. If it is indeed a different turbo, then the numbers between mine and what you show there don't compare at all.
There will also be a difference in spool with the MIVEC system on the IX also. Did the BBK run on the IX? My guess if that is true then that is why you saw the faster spool than the other turbo, however I have no idea where it should start for that HTA as it is a different setup than what FP uses.
Thanks, and sorry for the confusion.
Old Feb 13, 2010 | 11:16 PM
  #49
burnzy's Avatar
well, it uses the FP 80mm cover and HTA73 wheel, with 10,8 hotside and a smaller turbine to help spool. In theory I would expect the bbk to spool earlier but less top end than the HTA. The results I've seen so far speak otherwise though.
Old Feb 14, 2010 | 05:30 AM
  #50
Steve93Talon's Avatar
Is this GT Pumps version made by FP to their spec, or is it a knock-off?
Old Feb 14, 2010 | 08:53 AM
  #51
buchnerj's Avatar
Something just doesn't seem right to me, because if it was really tuned and that car had some decent supporting bolt-ons I KNOW an HTA Green would be over 400. I had mine professionally tuned and even did some tuning of my own and it is over 450 on E-85 which only has a RON of ~105.
I realize it might be a low reading dyno, but so was the Mustang Dyno that I had mine tuned on.
Old Feb 14, 2010 | 09:59 AM
  #52
Evoryder's Avatar
You can always tell BBK owners and fp red/green owners by their posts lol ..so defensive.
Old Feb 14, 2010 | 04:05 PM
  #53
buchnerj's Avatar
I am not getting defensive, I am just trying to understand as to why that number is reading so low. Especially while it is running on basically race gas, something just doesn't add up.
Old Feb 14, 2010 | 04:27 PM
  #54
burnzy's Avatar
100RON here is about 94 your octane. and remember out dynos read much lower over here, a stock evo will dyno about 150kw at the wheels.
the gt pumps turbo is using real FP cover and wheel.
Old Feb 15, 2010 | 12:26 AM
  #55
94AWDcoupe's Avatar
Burnzy, comparisons from two different cars is about as useless as it gets . The HTA green will make more power than BBK on both pump and race. And it only gives up 50-100rpm spool. Its a better turbo.
Old Feb 15, 2010 | 12:46 AM
  #56
Erik@MIL.SPEC's Avatar
Maybe I missed it, but where is this info located at? I have not seen an HTA Green vs. BBK comparison.
Taking what you said on faith, it seems like the forthcoming BBK-B might be more of a direct comparison to the new HTA Green than the BBK.
Old Feb 15, 2010 | 08:19 AM
  #57
94AWDcoupe's Avatar
the only real comparo done was by FP themselves. they dont post results for fear of slighting results and BS threads.
Old Feb 15, 2010 | 04:47 PM
  #58
burnzy's Avatar
it's not like i tried to pretend they were same cars, I stated they were the only 2 results we had in australia and to take away from it what you will. How much extra power did the HTA make over the bbk? For me what matters is that the bbk will max out my stock block on meth without losing too much spool.
I loved the HTA green as much as anyone else. That HTA green graph I posted isn't a "real" hta green though so as a said, make up your own opinions I'm just putting info out there.
Old Apr 7, 2010 | 05:21 PM
  #59
Aza's Avatar
Aza
u just confused them now burnsy. this is the turbo he is talking about NOT the FP Green. It uses some green parts but it isnt the same turbo. It is a knock off made here in Aus by GT Pumps
Not many people over here are running the Green HTA yet. I actually have one sitting in my garage though that I am putting on this weekend. Im abit nervous considering i have found jack all results on it. Exciting times Aus dynos do read lower than yours though as burnsy mentioned.
Old Apr 7, 2010 | 08:32 PM
  #60
burnzy's Avatar
lol.. i said it's not the "real" hta green
