Horrible hesitation
Old Feb 3, 2010 | 07:32 PM
EriCS's Avatar
Horrible hesitation
My evo is hesitating in between shifts when I go WOT in the next higher gear. It basically almost seems to delay in the surge of boost when I press the go pedal. I installed a larger fmic, licp, and uicp but I think it has been acting up before the install. I did a boost leak test and didn't find any leaks after the install plus I really don't feel this would cause the hesitation due to the fact really happens before spool up. The car hasn't been retuned since the install. I am also getting a lot of diverter valve flutter when I come off the throttle after low boost. Whats your suspicions?
Old Feb 3, 2010 | 07:40 PM
NJ_EveOhVIII's Avatar
what BOV are you using?
Old Feb 3, 2010 | 10:24 PM
8-BallEvo's Avatar
BOV. Had the same exact problem with my HKS SSQV going VTA. Not doing recirc will destroy your drivability.
Old Feb 3, 2010 | 10:35 PM
smokedmustang's Avatar
If you haven't been tuned after adding those parts, its your ECU "Hesitating" by saying: "WTF is all this new air i detect"?? and the ECU is compensating for this NON STOCK airflow. I say retune it, with the new mods, or you can put the stock parts back on, and see if it still does it, if so, its not the new parts.
8 ball, he never said what BOV/diverter valve he is using... lol
Old Feb 4, 2010 | 09:14 AM
8-BallEvo's Avatar
Well it sounded exactly like a bov problem I had so I assumed ****! Haha
Old Feb 4, 2010 | 09:22 AM
Wat00756's Avatar
could be a boost leak that always seems to be the problem for me
Old Feb 4, 2010 | 10:14 AM
gsrboi80's Avatar
Could be that you put you DV on backwards. Bottom Port needs to go to the UICP and side port to the intake
Old Feb 4, 2010 | 04:25 PM
EriCS's Avatar
I have the stock ix diverter valve. I doubt the diverter valve is backwards but I will double check.
Old Feb 4, 2010 | 04:32 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Get the ****ing car tuned you goon! Stop being cheap
