AWD Motorsports Round #2 of Testing with FP BLACK on the " Bastard " EVO!!!!
SubscribeEvolved Member
Keep up the good work Mike. Let me know your finding on the new dump when it arrives! Thanks
Mikey
Mikey
Quote:
Mike
mike and you please do a before and after when you put the DS on. it shouldent be to hard no??Originally Posted by Mike@AwdMotorsports
Yes we will be adding the driveshaft by event time in a couple weeks.. we need to shed around 40lbs off the car to make 2900lb weight min for the race..Mike
Quote:
Ill see what i can do.. there will be too many changes at 1x next time it dynos.. such different wheels and tires, brakes, DS and who knows what else.. we have parts that added weight such as full exhaust and larger FMIC so we need to drop some also..Originally Posted by evodan2004
Mike
awesome results Mike, very impressive. I hit a wall at 715awhp and 609tq on the HTA86 and stock ecu/mas ...boost increased tq from 540 to 609 but hp barely went up from 705 to 715 when going from 38 to 45psi. I'm not sure if I have a mechanical issue or airflow restriction at high rpm yet, so I'm very interested in your results when you push it harder.
Quote:
Thanks Mellon!!!Originally Posted by [I.R.A.]_FBi
mike, going sd in the future?
We will be going Sd after exploring how far stock ecu and Maf can go..
Mike
Mike, have you had to rescale the MAF or fit it into a bigger tube to achieve this? Was the MAF not full scale (maxxed out) at that power?
Conrad
Conrad
Quote:
Conrad
Minor adjustments to Maf scaling. Not sure what you mean by is it maxxed. are you referring to the 380% load limit? If so, that has been bypassed, and we are now hitting ~500% 1 byte load.Originally Posted by Conrad
Mike, have you had to rescale the MAF or fit it into a bigger tube to achieve this? Was the MAF not full scale (maxxed out) at that power?Conrad
Quote:
Yeah I was referring to the MAF load limit being maxxed out. If you have rescaled it and set a new load limit I see how you have got around it Originally Posted by diiirk@AwdMotorsports
I suspect I may need to do the same on my FP black then
