Sad discovery!!
Old Feb 5, 2010 | 05:06 PM
bbyevo8u's Avatar
i would not drive that car much until its fixed!! its a matter of time before it go's boooom then yell have some real damage or you might loose a leg!!
Old Feb 6, 2010 | 05:58 AM
lelek's Avatar
when i got my car ithad the same thing , just replace bellhousing . its around $300 plus work , unless you can do it yourself
Old Feb 6, 2010 | 09:45 AM
Nasty Evolution's Avatar
What flywheel do yo have? I could see the flywheel letting go long before the ACT clutch parts.
Old Feb 6, 2010 | 10:26 AM
vikevo9's Avatar
Stock flywheel
Old Feb 6, 2010 | 01:29 PM
boost_em1's Avatar
only way to tell is to just take it apart and actual c it.. i wouldnt trust it like another person said it can blow apart they have b4 with bad results
Old Feb 6, 2010 | 01:33 PM
2003lancerevo8's Avatar
I wouldn't drive it other than to get it fixed...
like said before, this will cause more issues if it breaks than what it will not driving it and getting it fixed...
be careful with that thing..
Old Feb 6, 2010 | 01:49 PM
BLK_EvIL's Avatar
I would take off that transmission asap see whats really going on
Old Feb 7, 2010 | 05:01 PM
Steed77's Avatar
another vote for a new one ASAP... That can get ugly fast.
Old May 5, 2010 | 11:23 AM
vikevo9's Avatar
Finally have the time and money to remove the tranny.... And found that the flywheel pins where missing... and the mess was big!!!
Old May 5, 2010 | 11:26 AM
Joshs EVO's Avatar
Ya I would stop driving it until it's fixed. There is a video on streetfire or youtube of a guy reving his friebird (i think) and the clutch explodes and pieces of it go through the floor board and into the dashboard.
Old May 5, 2010 | 11:43 AM
boozeup&riot's Avatar
If you cant replace it yourself, take it to a shop you trust. This has "sucker soak" written all over it. By that I mean that they will try to soak you if you look like a sucker.
"We looked at it and you need a new everything..."
If the car drive fine and what not, it *could* be that the housing was dropped while the new clutch was going in. That would at least explain why things internally are ok but not so much on the outside. Either way, I wouldn't drive it until its resolved.
Old May 5, 2010 | 11:49 AM
fugiwara's Avatar
Originally Posted by vikevo9
As odd as it seems the car runf fine.
It runs fine for now doesn't means forever, better replace it ASAP.
Old May 5, 2010 | 01:08 PM
vikevo9's Avatar
Wink
It's already removed and in the process of replacing all damaged parts, and this time a twin disc clutch.... and pistons, rod, cams, valves(1mm over), port 'n polish, bigger turbo, bov, wg.....
Old May 5, 2010 | 02:30 PM
Ev0ikon's Avatar
hAHA..Nice.. don't just rebuild. Rebuild Bigger and better!
Old May 5, 2010 | 07:10 PM
goldtooth's Avatar
stress fracture?
