evo ix turbo on evo viii
Old Feb 4, 2010 | 09:22 PM
screwnutbolt's Avatar
im bout to buy a 2006 evo ix turbo off some guy for $450 with an aftermarket O2 housing. i was just wondering if its worth putting an evo ix turbo in an evo viii, ive heard its good, but does it increase turbo lag? or anything else i should know? thanx
Old Feb 4, 2010 | 09:26 PM
buchnerj's Avatar
Technically speaking it will be a little laggier, however you will never be able to really tell the difference. The IX will be able to flow more air, therefore netting more horsepower and torque than the 9.8 your VIII turbo can. That sounds like a good deal, port things up and start modding.
Old Feb 4, 2010 | 09:34 PM
yeah i read somethin bout some guy that dynoed his car before and after an evo ix turbo install, and without a tune he gained 25 hp throughout the powerband. sounds good to me. im just curious if he ever got it tuned and what he ended up with.
Old Feb 4, 2010 | 10:04 PM
do i really need the evo ix to evo viii install kit? or is that just a load of BS
Old Feb 4, 2010 | 10:05 PM
buchnerj's Avatar
The oil lines you have (for an VIII) will not bolt right up to the IX turbo. Either buy the kit or plan on making something yourself.
Play it safe, buy it.
Old Feb 4, 2010 | 10:10 PM
whoang40's Avatar
You don't need the install kit. Just find someone that has the evo 9 J-pipe to replace the 8 turbo pipe. Order up copper gaskets from mits. and call it a day. The water lines have to be bent a little to line up.
Old Feb 4, 2010 | 10:12 PM
sweet thanks for the help guys. appreciate it.
bluebanana23's Avatar
Just bend the oil and water line. The J pipe has to be sourced from a IX. Port your exh. manifold while you're at it. The lag isn't too noticable but it's there.
Old Feb 4, 2010 | 10:15 PM
i dont have a stock exhaust manifold, i currentlty have the megan racing header installed. (staind like crazy btw...dont plan on keeping it)
Old Feb 4, 2010 | 10:18 PM
whoang40's Avatar
Oil lines will line up, when I installed my green turbo, same compressor cover as the evo 9 turbo. You can see when I installed mine on my old 2005 I had to use a hammer to slightly bend the coolant line above the compressor.
Old Feb 4, 2010 | 10:19 PM
and honestly im not picturing this pipe you guys have been talkn about. j-pipe? turbo pipe? i feel dumb right bout now
Old Feb 4, 2010 | 10:23 PM
whoang40's Avatar
If you look at my pic above. It's the black pipe that bolts to the compressor side of the turbo. The other side connects to your LICP via the coupler under your car.
Old Feb 4, 2010 | 10:27 PM
kool got it, thanx man. cant wait to install this thing and sooner or later get on a dynojet for a tune!
Old Feb 4, 2010 | 10:39 PM
so that like 6 inch plastic pipe is what i need from an evo ix right? just checkin myself thanx
Old Feb 4, 2010 | 10:46 PM
http://images.craigslist.org/3m93p23...3b091d1ea2.jpg
this is the setup im buying.
