Nissan Versa battery?
Old Feb 9, 2010 | 03:39 PM
Enzo1089's Avatar
So my buddy's Nissan Versa just got totalled and we were thinking about putting his battery into my car instead of buying a Mini Battery for a Short Route ETS UICP. What do you guys think?
Old Feb 9, 2010 | 03:41 PM
Enzo1089's Avatar
Battery Specs:
Its a 2008 Battery
Width: 6.8
Length: 9.6
Height: 7
CCA Rating: 470-530cca
Weight: Unknown at this time
Old Feb 9, 2010 | 04:12 PM
SavEVOIX's Avatar
Copy and pasted from the odyssey PC680 site
PC 680 Specs:
680 cranking amps for 5 seconds
595 cranking amps for 10 seconds
525 cranking amps for 20 seconds
17 amp hours
Short circuit current over 1800A
25 minute reserve capacity with 25amp load
Female brass terminal w/M6 SS bolt
Length 7 1/16"
Width 3"
Height 6 9/16"
Weighs less than 15 lbs
Old Feb 9, 2010 | 04:38 PM
Enzo1089's Avatar
I've heard a lot mixed opinions on the Odyssey batteries. So people say they are fine, but I've also heard complains of them dying really fast.
I figure with this being a OEM battery, it should last longer and work well in the cold.
Old Feb 9, 2010 | 04:41 PM
Enzo1089's Avatar
I was just reading a lot about people using Miata, and Civic batteries instead of small batteries, and I figured this battery is about the same size as a Civic, so why not.
Old Feb 9, 2010 | 04:44 PM
boosted91t's Avatar
Do you have a pic of the versa battery? I googled it but had no luck
Old Feb 9, 2010 | 04:50 PM
Enzo1089's Avatar
He gets the car back from the shop some time this week, I'll take a pic then.
Old Feb 9, 2010 | 07:23 PM
SavEVOIX's Avatar
Will it fit? The width is almost double.
Old Feb 10, 2010 | 05:30 AM
kiley_sean's Avatar
There are a few guys who run the miata batteries (modifying their stock tray). I think the Civic battery is a little bigger than the miata battery. Anyways, the battery you have should do a lot better than any of the mini batts in the cold weather.
Boostlogic makes/made a battery tray for the miata battery to fit in the evo.
I was going to run it (BL tray), but because it is spun sideways like other mini trays, and it's a longer battery, you can't run a stock airbox/ARC airbox.
Anyways, yeah. I think the miata battery is the way to go.
Old Feb 10, 2010 | 05:50 AM
MJ23FE's Avatar
PC 680 Specs:
17 amp hours
Length 7 1/16"
Width 3"
Height 6 9/16"
None of these are CCA which is what matters.
My buddy was working on an X6 at his shop, and the battery is located in the trunk. The battery is HUGE, like 2 feet wide and just massive. The CCA was listed on it and it was like ~900! Ridiculous!
-Jalal
Old Feb 10, 2010 | 08:43 AM
travman's Avatar
-Jalal
PC680 has like 220cca.....so far mine has been good in the eastern winter, first year with it and hasn't let me down - but on real cold days it def. cranks slower.
Old Feb 10, 2010 | 08:50 AM
Enzo1089's Avatar
Civic Width: 5.1
Versa Width: 6.8
Not really close to double, but it is bigger. We get the car back today from the body shop, so I'll get pics and probably try to install it tomorrow. Hope this works
Old Feb 10, 2010 | 08:51 AM
Enzo1089's Avatar
^^Oh you were referring to the width of the PC680. My bad.
Old Feb 10, 2010 | 09:00 AM
travman's Avatar
http://optimatrays.com/viewitem.php?type=battery&id=25
there is a nice option with a miata battery tray.....450cca. If I have issues with my PC680 I may switch and build a new tray and get this battery.
Old Feb 10, 2010 | 09:13 AM
turbolarry's Avatar
Rock the versa battery and let us know how it goes.
