HKS Rods
Old Feb 11, 2010 | 03:40 AM
CAM 6's Avatar
HKS Rods
Could anyone tell me what the maximum HP the HKS H Beam rods will hold?
Cant seem to find any spec on them?
Thanks
C
Old Feb 11, 2010 | 09:58 AM
Ted B's Avatar
At $1700 USD per set, I'm not sure why anyone would really bother to find out. With proven top-tier rods like Oliver, Carrillo, etc., available for much less, there is little reason to care about them.
Old Feb 11, 2010 | 10:00 AM
need_an_evo's Avatar
go with oliver man you wont regret it.
Old Feb 11, 2010 | 10:09 AM
n2oiroc's Avatar
but oliver isnt mad tyte jdm baller yo!
Old Feb 11, 2010 | 10:12 AM
TTP Engineering's Avatar
Thanks
C
First of all you should review what the power goals of the car are before determining the rod to be used.
No one should really be making recommendations until this much is known.
Old Feb 11, 2010 | 11:34 AM
JC evo1's Avatar
do hks rods come in a baller case?
Old Feb 12, 2010 | 02:35 AM
CAM 6's Avatar
The reason for the question is - i have 2ltr forged with CP Pistons and HKS H Beam rods in at the moment....I was running a Full Race 3076r Turbo Kit...but i have recently upgraded to the Garrett Full Race GT35r turbo...hence the hike in power,hence the question.
So again does anyone know the spec of the HKS H Beam rods?
Old Feb 12, 2010 | 03:25 AM
project_skyline's Avatar
If its the same rod ran in the CTA9 TA car they made, im sure you'll be fine.
Old Feb 12, 2010 | 03:48 AM
Sharkbite2000's Avatar
So many rod's I've been running 2 years making over 600 daily and just shy of 800.
With that price of that HKS rod's you can buy a new engine from BR or AMS and call it day.
Old Feb 12, 2010 | 04:27 AM
4ukc's Avatar
I beleive for that setup you dont need HKS carillo would be good
I also think that with that price you can get a nice stroker set)
Old Feb 12, 2010 | 04:37 AM
nudge120's Avatar
Hope this helps. Unless your looking for me to sell you on another set of rods, when your car already has these
"HKS Connecting Rod
See other Engine - Connecting Rods An H Beam Connecting Rod has been newly introduced to accommodate high output for tuned engine. The rod was newly designed by computer stress analysis in order to accommodate more than 600-horse power. Durability has been increased by implementing WPC as surface treatment. The connecting rod can be installed on normal pistons and normal cranks because the pin diameter and center length were made equal to those of factory designated units"
"HKS CONNECTING RODS
HKS H-Section Connecting rods are designed for high performance engines in which expansive stresses during high rpm often cause a factory supplied connecting rod to fail. Designed using advanced CAD and FEA engineering software, the rods have been specified from high grade treated and conditioned billet steel. The result, is a connecting rod suitable for the most demanding engines with a racing purpose"
Old Feb 12, 2010 | 07:27 AM
CAM 6's Avatar
"HKS Connecting Rod
Thankyou Nudge
Thats more like the answer im looking for mate
Would still like to see a spec sheet tho.....
Old Feb 12, 2010 | 07:52 AM
ryno529's Avatar
Your rods are fine i would be more worried about the pistons. If you have the CP pistons with the regular wrist pins i would be careful. A friend of mine collapsed a set of standard CP wrist pins on a stock 9 turbo (30 psi), since then i will not order a set of CP pistons with out the HD wrist pin upgrade.
Old Feb 20, 2010 | 08:07 PM
4g63 gsr's Avatar
how are the eagle rods if used with eagle crank and piston such as ross ,wiseco ,je or cp
will it hold 700 wheels
Old Feb 22, 2010 | 03:04 AM
4ukc's Avatar
eagle are OK pauter is also good, but I believe Carillo - the BEST)
