To short shift or not to short shift.. That is the question
Old Feb 13, 2010 | 09:03 PM
itsurismicah's Avatar
Ok I need some feedback here. What is your favorite short throw and why, do you even like any? I'm looking for one that is as smooth an install as my revo was for my RSX
Old Feb 13, 2010 | 09:22 PM
Brokenevo's Avatar
do it,
Old Feb 13, 2010 | 10:46 PM
e\/olution's Avatar
i just did mine so ill chime in..
got the works short throw kit through maperformance, it comes with the retainer clip and pivot cups when you buy it, so no messin around with the stock ones.
Install was very easy, i did it along with some speedsource shifter base bushings, took about an hour total.
def not going back to stock, shifts are shorter, and feel more crisp, also there is no play anymore , and it feels great with my blox knob.
link to short shifter diy http://www.joe250.com/cars/evo8/shor...rtshifter.html
and might as well do the shifter base bushings while your in there.. http://www.joe250.com/cars/evo8/shif...ebushings.html
start from the 3rd picture from the bottom
Old Feb 13, 2010 | 11:13 PM
05BlackBeast's Avatar
Nice looks good. Definitely worth doing!!!
Old Feb 13, 2010 | 11:21 PM
e\/olution's Avatar
yea props to joe250 hes got a bunch of diy under the evo sections of his website, check it out
Old Feb 13, 2010 | 11:22 PM
Very nice write up I appreciate the detailed pictures. Did you notice a change in the hieght of the shifter was well as the throw?
Old Feb 14, 2010 | 08:27 AM
Kracka's Avatar
YES! A short-shifter is a great addition to the 5-speed. My recomendation is the one found on eBay for $29 shipped. It is identical to the Fidanza and B&M down to the box and packaging (I bought them all to confirm this). It even includes a set of shifter base bushings which alone normally go for almost $30.
http://cgi.ebay.com/ebaymotors/Lance...Q5fCarQ5fParts
My install pictures and instructions:
http://www.mitsustyle.com/forums/showthread.php?t=19267
Old Feb 14, 2010 | 08:45 AM
e\/olution's Avatar
i believe it did shorten it a little bit, as soon as i put the knob on i noticed it but its not drastic
Old Feb 14, 2010 | 10:05 AM
deadmeat's Avatar
Damn after reading this thread I want to get one now too.
Just a quick (stupid) question. That ebay listing only has 01-05 models listed. I'm assuming I can still use it even with an Evo IX (5 speed of course)?
edit - Looks like it'll be fine.
Old Feb 14, 2010 | 10:11 AM
evo_rc's Avatar
short shifter+bushings+razo ra122=SEX
Old Feb 14, 2010 | 10:12 AM
ncaruso23's Avatar
Personally I see no point in a short shift. I like the feel of the the stock throw, But I hate the feeling of a sloppy shifter. What I did was in-car and under-hood solid aluminum shifter bushings from AMS. If I were you I would try that first and see how you like the feel and see if you still want the short shift.
Old Feb 14, 2010 | 11:49 AM
Svendiesel's Avatar
Interestingly enough, when I contacted Shep about my trans swap, I asked him if we could leave out the Shifter that he included in the 6spd to 5spd conversion kit because I wanted to buy a short shifter.
He recommended I do not buy a short shifter and stick with just the stock shifter.
I wondered why, I never asked for some reason. I just figured if John Shepherd said stick with the stock shifter, that was good enough for me
Old Feb 14, 2010 | 05:19 PM
randomevo's Avatar
I have also heard some bad reviews about short shifters so i would love to be reminded again about why its a BAD idea
Old Feb 14, 2010 | 05:34 PM
SLO-EVO's Avatar
i am running B&M short shifter with all aluminum bushings under hood and shifter base... nothing but good things to say... only complaint is that you occasionally miss a gear because i have ZERO play in the shifter... crisp and precise... but I LOVE IT!!!
Old Feb 14, 2010 | 05:39 PM
bougs's Avatar
Its puts additional stress on the transmission when using short shifter. If the gearbox balks you will have more speed from the short shifter potentially causing a problem.
