DIY air box
Old Feb 15, 2010 | 09:27 PM
McDougal's Avatar
DIY air box
I made this today using some pieces of aluminum that I got for free. I have no idea if it will lower the air temperature in the area of the intake, but I figure it can't hurt. It isn't perfect by any means, but I think it is pretty good for not having anything but some shears to cut the metal with. If anyone is local and wants to do some logging to see if it makes any difference let me know.
Old Feb 15, 2010 | 09:34 PM
MitsoKid's Avatar
I would imagine it would have some effect with keeping the heat away from the intake. Its putting a barrier between that super hot manifold and your intake and your flowing in air on the top. Looks good, good job
Old Feb 15, 2010 | 09:43 PM
McDougal's Avatar
Thanks. I figure it can't hurt. I have some more metal so I might have to make another one.
Old Feb 15, 2010 | 09:45 PM
MitsoKid's Avatar
you could make another one and try to clean it up and make it fit tighter around the intake but otherwise I think it looks good. I'm running a carbon fiber heatshield similar to that
BLK_EvIL's Avatar
nice did this on my 2G gsx only with a ram air duct going up to it lowered the temps about 25 deg
Old Feb 15, 2010 | 09:53 PM
McDougal's Avatar
I have some more metal sheets so I will probably do this.
Old Feb 15, 2010 | 10:31 PM
BluEVOIX's Avatar
Seems good.
But if you have a lot of metal sheets why not also make a rear underbody (diffuser). Just a thought.
Old Feb 15, 2010 | 10:32 PM
McDougal's Avatar
Originally Posted by BluEVOIX
Seems good.
They are too small.
Old Feb 16, 2010 | 05:00 AM
4WS Tuning's Avatar
Nice idea man.... I dont see why it wouldnt help =-)
Cheers!
Old Feb 16, 2010 | 05:07 AM
MR Turco's Avatar
looks good. Anytime you isolate the filter from the air passing through the radiator you should see lower IATs. I have actually been wanting to make one of these for a while.
Old Feb 16, 2010 | 11:00 PM
McDougal's Avatar
Just go to a sheet metal shop and ask to buy some scraps of aluminum. I bet they wouldn't charge you more than a few bucks a sheet. You'll need a set of metal shears, or better yet some sort of cutting wheel on a dremel (what I used). Also remember to wear gloves or you will cut a finger off.
Old Feb 16, 2010 | 11:50 PM
ace33joe's Avatar
I like how those shields are fixed firmly with bolts! I hope someone mass-produce effective heat shields for universal open-type air filters. Actually the only reason I still keep my stock air box with a drop-in filter is the lack of good heat shields.
Old Feb 16, 2010 | 11:56 PM
EvolutinIX's Avatar
Looks great! Where do i order!? j/k
Old Feb 17, 2010 | 06:12 PM
McDougal's Avatar
I could make them so that all you would have to do would be attach the bolts. Wouldn't be very expensive.
MonsterParadise
Aug 12, 2013 11:03 PM
2theMAX
Jul 2, 2013 07:40 AM
eXtreme-Speed
Jan 18, 2011 04:16 PM
raytrix
Oct 28, 2010 07:10 PM
LV///R
36
Apr 12, 2010 06:54 PM
