building block evo 8 advice plz???
Old Feb 20, 2010 | 01:42 PM
4g63 gsr's Avatar
hi i am running evo 8 with gt35r and we are about to purge 50 to 100 shots of nitrous to the car
1.bought a block core
2.i bought a eagle crank with eagle rods..
3.have both clevite and acl bearing kits
on this setup i need good advice for pistons ..goals 650 to 700 whp
pistons options ...ross,je coated,wiseco coated or cp if they make
wht compression of pistons i need plz tell
more mod parts are ordered such as new oil pump,water pump,ati super damper and arps..
any kind of feedback will be a good help thank you
Old Feb 20, 2010 | 01:50 PM
n2oiroc's Avatar
why nitrous? and a 35r with a 100 shot sounds like a bad idea with eagle rods.
Old Feb 21, 2010 | 12:51 PM
4g63 gsr's Avatar
wht rods should i go for pauter ,manley or carillo
will eagle crank support these kind of power to it on diff rods added...thanks...
Old Feb 21, 2010 | 02:54 PM
sonicnofadz's Avatar
Eagle crank will be fine, hell a stock crank would have been fine. You should have bought better rods (pauter or carillo are very good choices) and just used the OEM crank. Make sure you double check all your clearances with a bore gauge AND plastigauge and also use lube on everything.
Hotsauce101
Oct 18, 2015 06:02 PM
Sideck
Feb 13, 2015 07:06 PM
xspsi4
Jul 27, 2009 09:12 PM
Perk77
Aug 28, 2008 07:59 PM
Jackson Machine
18
Sep 14, 2006 09:57 AM
