Is this ok spot for boost soruce
Old Feb 20, 2010 | 02:21 PM
ant_turbo's Avatar
Just making sure if the spot i taped is ok for boost reading.. And also is it ok that my ZEITRONIX MAP/BOOST is taped into the same line?? THANKS...
Old Feb 20, 2010 | 02:34 PM
Psquared's Avatar
That should be fine. Where is that hose running? Isn't that the oem location for the stock bov hose?
Old Feb 20, 2010 | 02:36 PM
Pal215's Avatar
^ Yes it will be fine. However, why not just use the FPR hose?
Old Feb 20, 2010 | 02:49 PM
ant_turbo's Avatar
what's the diff installing it on the FPR side
Old Feb 20, 2010 | 03:00 PM
Psquared's Avatar
I wouldn't tee into the fpr hose. More chance of it blowing a hose off. If it does, your fuel pressure will drop to base pressure under boost. I'd tee into the other short hose that's near the fpr hose in your picture. It's near your dipstick in the pic.
On a side note, I would zip tie the fpr hose to the fpr. There isn't a barb on that fitting, or a hose clamp to keep it on. Just an extra bit of insurance.
Old Feb 20, 2010 | 03:01 PM
ant_turbo's Avatar
What about my Zeitronix map sensor!! It's taped into the same line for my boost gauge
Old Feb 20, 2010 | 05:22 PM
ant_turbo's Avatar
Ok so bottom line!! where I T into is just fine,,,??
Old Feb 20, 2010 | 08:31 PM
Zeitronix's Avatar
Fuel pressure regulator is usually a good place to tap for the MAP sensor (boost gauge). If the line pops for any reason you have no fuel pressure increase under boost but you also will not see any boost reading on the Zeitronix gauge. It gives you a check for one of the most important little hoses is there.
Old Feb 20, 2010 | 08:53 PM
Turbo01s2k's Avatar
NEVER tap your FPR line. There are many other sources...its just not smart. you want a direct source to your FPR
