Car almost stalls when dropping hood + P0170
Old Feb 26, 2010 | 03:33 AM
HaVoC187's Avatar
The car was first registered here March 2008.Evo X came to US late 2007,we had to wait till early 2008.
Old Feb 26, 2010 | 03:35 AM
HaVoC187's Avatar
Originally Posted by rgeier11
+1 on boost leak. Almost 100% for sure.
Will test for leaks tomorrow.
Old Jan 1, 2011 | 01:53 PM
DutchEVOVIII's Avatar
Originally Posted by smokedmustang
*side note* if you run around the idling car in your Belgian wooden shoes, the knock sensor may pick that up too?? LOL. jk, I rarely get to use Belgian wooden shoe jokes anymore.
LOL a bit late i know, but i was searching for P0170 & P0125 since my Evo VIII recently started giving that code. I did'nt know about the knock sensor being that sensitive. But in Belgium they dont wear wooden shoes. Only in those parts very close to the Brabant-Belgium border. Wooden shoes are Dutch lol
But anyways, HaVoC187 what was the problem? I assume it must have been fixed by now?
i have both code:
P0170
P0125
But it only pops up when driving with a constant speed on the highway?
Old Jan 1, 2011 | 04:20 PM
batty200's Avatar
DON'T use Brake cleaner. Use the MAF specific spray. Other stuff may ruin the wire in there. I say you have a boost leak somewhere! Check ALL connections period. There are nipples on the throttle body, make sure those small vaccuum lines are attached too. It is a simple fix, but I put my money its in the hoses.
Our cars are not nearly as sensitive to the wire cleaning as other cars. OUr car dont use a hotwire type MAF the use a karman vortex. The GM MAF is a hotwire sensor and much more vulnerable to the wrong cleaner. Also a hot wire maf should obviously not be cleaned when the car is on. It isnt a bad idea to use MAF cleaner but isnt as critical on a mitsu using stock MAF.
Old Jan 1, 2011 | 04:27 PM
milford's Avatar
your picking up knock from the slam...
Old Jan 3, 2011 | 08:06 AM
browningderek's Avatar
my car misses a beat when i drop the hood too. running SD on AEM V1 so its not MAF related.
but my car has always done that since it was new. damn mitsu...... LOL
Old Jan 4, 2011 | 02:33 AM
HaVoC187's Avatar
i have both code:
P0170
P0125
The P0170 was due to a faulty front O2 sensor.Dealer wants 340€ for this so get one here:
http://www.walkerproducts.com/
Cost me about 80€ including shipping.
Old Apr 3, 2018 | 07:45 PM
canberraevo9's Avatar
Okay just to add to this thread I had the same issue with my Evo 9, traced the fault to dry joint in the MAF, confirmed by tapping the Maf with the handle on a screw driver. The car would also drop power
for a fraction of a second if I hit a big enough bump in the road, I was originally thinking fuel pump as I have 268,000 km on my car lol
SavageGSR
May 15, 2016 08:36 AM
bnr34rb26dett
Oct 6, 2015 01:09 PM
Evv007
Aug 10, 2015 09:37 AM
powerstroke
Aug 8, 2014 03:04 PM
rice_rocket88
Feb 28, 2011 06:59 AM
