INLINE RACING -2.0l MOTOR BUILD w/ PICS
Old Feb 26, 2010 | 07:06 AM
TakaseEVOIXSE's Avatar
Thx for all the comments guys. We'll be back w/ more updates later as things progress!
Old Feb 27, 2010 | 08:15 AM
zedevo's Avatar
Awesome Explanation ... and good luck
Old Mar 1, 2010 | 02:08 PM
think0rz's Avatar
looks like a great build best of luck to you guys
Old Mar 1, 2010 | 09:53 PM
GST Motorsports's Avatar
"We" meaning you are a employee of Inline Racing?
Are they a vendor on Evom?
- Bryan
Old Mar 1, 2010 | 10:05 PM
WRXGONE's Avatar
how much?
Old Mar 1, 2010 | 10:13 PM
redleg225's Avatar
I agree with GST; you have to pay to play brotha'.
Good thread though. Keep us updated.
Old Mar 2, 2010 | 09:51 PM
Originally Posted by mchuang
He clearly states in his first post he is a friend of the owner. So am I, the owner actually only posted clearance specs under my username because I stayed logged into his laptop (my bad). He says "We" because the owner aka his friend is helping him with the build on this vehicle. As much as I respect the things you have done for this forum, don't start throwing that vendor BS around as he is not trying to sale anything or advertise, he is just speaking out of excitement because its his car.
I totally understand and I agree with you. I got wrist slaps when I was posting dyno sheets without vendor status, so we got one. I just think the same applies here, unless you are more careful with your posting style. Picking up what I am putting down?
Either way the motor build looks great. I'm tossing around ideas for my personal motor build currently as well so it's good info.
- Bryan
Old Mar 3, 2010 | 07:31 AM
ryno529's Avatar
I was just looking over your engine build very nice. One more thing you might want to do before you go any farther is o ring the block SS or copper. With those power goals it will help keep you from blowing head gaskets and create a better seal.
Old Mar 3, 2010 | 09:18 AM
20gmr's Avatar
Interesting rod choice. Do the manley's use 6 bolt or 7 bolt rod bearings? I went with HOWARDS rods, from MAP, these use 6 bolt rod bearings and 7/16 rod bolts instead of most rods which use 3/8. I hear ya on the wrist pins, I got a set of HD's from JE
Old Mar 3, 2010 | 10:35 AM
that is a common upgrade as well. I do like your build
Manley TT runs 7bolt rod bearings. We researched the aged+625 rod bolts and they are more than capable w/ the 7bolt design. They are expensive but if you check the HP per cylinder rating you'd see they are worth it.
as for the wrist pins... you see where im coming from then, lol. ALOT of builders overlook this and blame the piston companies when they crack... when in fact they arent rated that high to begin with.
Old Mar 3, 2010 | 10:38 AM
- Bryan
Bryan,
thx for commenting and yes i hear ya.
wouldnt mind hearing about your build as well
-Tom
Old Mar 12, 2010 | 02:15 PM
have been busy w/ other stuff... but the head is now securely on the block w/ ARP headstuds and new gaskets. Cosworth M2 cams are going in tonight w/ an HKS exh cam gear (mivec only needs one) and a pretty neat purple HKS timing belt, LOL... That should button it up minus the Intake Manifold/Tbody which i havent decided what to do w/ that yet.
But at least we can get it in the car w/ the Shep 5spd transmission. Im going to try and use my semi new HKS GD pro twin disc clutch/flywheel and see how it holds up. Noone seems to know what the TQ rating is on these things but it worked great on my old 35r setup (577whp / 430ftlbstq) Since i have it, might as well use it... if it fails, i'll go w/ the tried/true QuarterMaster twin that has been working great in the other cars at Inline.
Updated pics to come.
-Tom
Old Mar 25, 2010 | 01:01 PM
UPDATE 3/25/2010
It was decided that the Intake Manifold would be custom fabricated instead of going w/ any aftermarket one currently available. Here are the CNC cut aluminum pieces for the Intake Manifold complete w/ angled velocity stacks. I'll post pics once all TIG welded together.
Btw, next update will be of the fabricated exhaust manifold once we position the turbocharger in front of the car.
-Tom
[IMG][/IMG]
[IMG][/IMG]
Old Mar 25, 2010 | 01:47 PM
RockmanX's Avatar
how much for the motor?? was not aware houston had any good preformace shops i hate that place so never bothered to look lol even though its like what 5 hrs or so from me. my friend is going to houston tomorrow actually wow kind of makes me interested to catch a ride and see it in person.
Old Mar 25, 2010 | 02:16 PM
PATRICK B.'s Avatar
Sub'd to see how things turn out........GL w/ the rest of the build up!
