Anyone else idle like garbage?
Old Mar 14, 2010 | 02:39 PM
  #31
GrimCreaper's Avatar
Mine was doing the same thing. I don't have cams and I run a OEM IX bov, but what I did was clean the Idle Air Control Sensor. My car has almost 100k miles and the iac was black, after I cleaned it it looks new and car runs great.
Old May 26, 2010 | 02:59 PM
  #32
shuttlegoose's Avatar
same problem. Tephra v7. fic 850 injectors. Stock ix bov. I really don't know what the problem is.
Old May 26, 2010 | 06:09 PM
  #33
Appauldd's Avatar
I found that the timing idle area greatly helps to be properly tuned. If you have your car idling higher than 1000 rpm you need to make the 1500 rpm area and the 1000 rpm area closer as too large of a gap in timing in this area creates idle issues.
Old May 26, 2010 | 07:16 PM
  #34
racer135's Avatar
I did some changes to my ROM and now my car idles great with the Kelford 272. Purrs like a kittent. With the A/C on you cant even tell the car has cams. I need to run it for a few days to see if it changes, but need some pads right now.
Old May 26, 2010 | 07:25 PM
  #35
mifesto's Avatar
if you are short on cash, trade the hks unit for a stock 9 one or buy the recirc kit.... problem solved.
Old May 26, 2010 | 07:39 PM
  #36
evo4life400's Avatar
i have a stock evo 9 bov and i have this same problem....i had throttle body shafts seals leaking so i fixed those and it helped a lot. the car still does it once in a while but it got much better once i fixed the seals
Old May 26, 2010 | 08:45 PM
  #37
italianevo88's Avatar
I ordered the recirculation kit today so ill post up if it fixes my problem.
Old May 26, 2010 | 09:19 PM
  #38
manray's Avatar
Originally Posted by italianevo88
Its getting to the point where its actually aggrivating to drive, everytime i come off the gas(in neutral) my car goes down to about 300 RPM and bumps around and then pops back up, but its really aggrivating at stop signs and such. im wondering if its the kelford 272s, the blow off valve venting to the atmosphere, or mabe how its tuned. but im looking for some suggestions, ive heard a new EMS(AEM,AUTRONICS) helps tuning, thus making it easier to get the car to idle, thats just what i heard though. -thanks in advance
I have the same issue. In my case I'm pretty sure it is the BOV (a tial - vta).
Old May 26, 2010 | 10:21 PM
  #39
rawkus's Avatar
Looking at your other posts, it sounds like you have a bunch of mods that may not have been installed properly... Take it to a reputable shop and have them look it over. If you want to drive to Indiana, I can look it over. Sounds like everything is kind of jank in general.
Dan
Old May 27, 2010 | 08:05 AM
  #40
hey rawkus, are you talking to me or manray
Old May 27, 2010 | 02:00 PM
  #41
rawkus's Avatar
You, sorry if I came off as rude. But before I would go into tuning (which still could very well be the problem) or changing the BOV (which should be changed) it sounds like you could have a vacuum leak or other issue. I have seen some extremely poorly screwed together Evo's idle just fine even with a BOV and screwed up fuel maps. So again, not saying the other folks aren't right, but I'd be glad to help look over the car if you want to drive over, could just be some simple things not setup right
Dan
Old May 28, 2010 | 10:34 AM
  #42
Oh i dont care everyones entitled to their thoughts, but you could be right seeing as how I got the car with most of the stuff done to it already. Im going to put the recirculation kit for the BOV on, it should be here tomarrow, and if that doesnt work ill contact you if I need some futher assistance- thanks
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
rs03evo
Apr 25, 2014 06:13 AM
03Evo8DTC
Northwest Region
24
Aug 1, 2010 10:48 AM
sing1002
67
Apr 14, 2009 02:28 PM
Alfriedesq
Apr 26, 2003 09:58 AM
