How do I remove Mivec Head from Block ?
Old Mar 5, 2010 | 10:12 AM
N33d4sp33d's Avatar
What is the easiest way to remove the mivec head from block ? What tools are needed and step-by-step procedure would be very helpfull !
Old Mar 5, 2010 | 11:21 AM
20gmr's Avatar
other then the obvious stuff, you need to remove the oil feed line that runs into the large gold mivec solenoid on the backside of the head timing side. I would just leave the cams in it. Why are you removing it?
Old Mar 5, 2010 | 11:35 AM
Evogirl80's Avatar
must be a brave soul to assume you're just going to remove something like your head without knowing anything. figure you're gonna just come on a forum and get a quick guide? good luck with that one. what are you doing?
Old Mar 5, 2010 | 11:53 AM
Walt's Avatar
You have to be very mechanicaly inclined, its not a easy task. You need special tools for the timing belt tensioner and must have torque wrench. Also must be at top dead center before you start the job.
I just put mine back together and started tuning after arp's, head gasket, turbo, yada yada...
I was a mechanic for years and you must know what your doing!
Check out gsc's web site on camshaft install which will have a link to service manual.
Old Mar 5, 2010 | 04:28 PM
SavEVOIX's Avatar
This well help http://www.evomoto.com/tech_articles..._article_id=18 get your started in what you need to do.
Old Mar 5, 2010 | 04:59 PM
still*boostn's Avatar
why in gods name would you want to remove your MIVEC?!?
Old Mar 7, 2010 | 06:13 PM
N33d4sp33d's Avatar
selling the shortblock
Biggy VIII
Aug 9, 2016 03:06 PM
asubennett
Mar 15, 2012 07:22 AM
droppedrx7
48
Apr 8, 2010 06:16 PM
Waz996
Sep 5, 2008 10:14 AM
KooIDud3
Jan 27, 2008 06:11 PM
