EGR.... is it needed?
Old Jul 20, 2012 | 05:08 AM
batty200's Avatar
Originally Posted by okevolutionVIII
You can but no real benefits will be had. Blocking off the port in the head and bypassing the throttle body coolant lines will keep the intake air cool, EGR releases hot exhaust air into the intake making it dirty and the air obviously very hot.
I would not recommend bypassing the coolant lines to the throttle body. The fast idle air valve will not work properly and you will have weird idle issues. The throttlebody temperature won't affect intake air temps much at all.
Old Jul 20, 2012 | 07:15 AM
okevolutionVIII's Avatar
I have a Boomba so I have no choice. I never heard of anyone having issues but I can see how it could affect idle with all the idle settings in the ECU.
Old Jul 20, 2012 | 07:35 AM
barneyb's Avatar
Originally Posted by chrisw
The EGR is hangover from the carburetor. It's useless in fuel injected engines.
One of the products of combustion is nitrous oxides. This is what was causing the haze in California. The higher the temperatures in the cylinder at ignition the more nitrous oxides formed. Engineers found that injecting a small amount of exhaust back into the cylinder kept the combustion temperature down. I don't see how this would be any different on a fuel injected car.
Old Jul 20, 2012 | 10:00 AM
gg2006ssl's Avatar
I am thinking about deleting it off the ecu because I have my engine light on right now and just want to clear it without having to change it. dont care of any benefits just dont want it to affect power. so are you saying that it will harm power if I just delete it?? thanks
fostytou
359
Oct 23, 2025 09:54 AM
breadn56
May 14, 2016 07:04 PM
hamilton_eddie
Lancer Troubleshooting
Sep 1, 2014 12:13 PM
Chris EVO 8
Aug 9, 2014 08:03 PM
svt_lightning01
Feb 20, 2012 05:39 PM
