arp head stud install torque specs???
Old Mar 5, 2010 | 10:08 PM
murderedevo256's Avatar
I have been looking around and I cant find any real specs on how to install them? I know you use the same method as stockers but I need the torque specs for them with the lube they provide. I thought there would be alot of info on it but it seems everyone does the 1x1 method and doesnt do a headgasket ever
Old Mar 6, 2010 | 08:29 AM
anyone?
Old Mar 6, 2010 | 08:38 AM
twabtoxer's Avatar
i took the risk of 1x1 method, so far no leaks and i check everyday its been 2 weeks. i keep knocking on wood thou because you never know. i started at 60lbs then went to 70lbs then finally 80lbs, i made sure the car was completely cool down i waited over night. there is information but you have to search and deal with numorous people telling you not to do it this way, lots of reputable shops do it 1x1 method , thou good luck!
Old Mar 6, 2010 | 08:51 AM
Bobster22388's Avatar
Torque Specs
http://www.arp-bolts.com/Tech/T3_Tor...lt1.html#Mistu
https://www.evolutionm.net/forums/ev...m-removal.html
I have used the 1x1 method on quite a few Evos and have yet to see any problems with any of them.
SDevol8
26
Mar 27, 2017 04:09 PM
DormantBeast
Feb 2, 2014 07:52 PM
blowngasket
Apr 13, 2013 10:40 AM
EvoAznBoi
Nov 28, 2011 09:35 AM
shadow1
Apr 12, 2010 12:20 PM
