stock 4g64 (2.4) bottom how much power?
Old Mar 8, 2010 | 05:30 AM
nos51's Avatar
just curious to know if anyone has ever run a completley stock 4g64 short block with thier evo head on it.im curious to know what kind of power they can hold up to.please dont come on here and say "you must build it,etc or else"i know all these things and i know of the consequences of pushing a stock motor but at the same time i want to know if any has done it and what are thier limits.im thinking about just throwing one in my evo for daily duties.....any help would be very apreciated!
Old Mar 8, 2010 | 06:29 AM
RockmanX's Avatar
so you want to put a unbuilt 2.4 in your car and see what it makes?? why would it make more then the average 2.4 galant or eclispe etc wherever you got it out of?
Old Mar 8, 2010 | 07:27 AM
[I.R.A.]_FBi's Avatar
maybe he's going for the 2.4 stock block record.
Old Mar 8, 2010 | 07:41 AM
nos51's Avatar
yes thats exactly what i want to do.it would make more because it has a better head (evo).im not trying to make crazy power or go for records,but maybe like 300hp more or less.again the car would be for daily driving not racing.
Old Mar 8, 2010 | 08:34 AM
RockmanX's Avatar
hmmm still dont see the point in this unless your going for a record to break. the whole point of the 2.4 is to get more of course if you want strictly dd with no bs then keep it stock 2.0. if yours is damaged then i kind of understand but you can buy a built one for just alittle above 3k yes you can get used cores for like 500 lol.
Old Mar 8, 2010 | 08:45 AM
redleg225's Avatar
The OP isn't asking people what the point of such a swap is or if it makes sense.
@nos51: Sounds interesting. I'm also curious how much power a stock 4G64 can make on a 16G. English Racing recently put a 16g on a built 2.4 and made insane amounts of torque with HP falling off after 5500 RPM. It really maxes out a stock turbo quick. You can look forward to 400WHP pretty easily though. Here's the thread I'm talking about:
https://www.evolutionm.net/forums/ev...ock-turbo.html
Old Mar 8, 2010 | 08:54 AM
GPTourer's Avatar
Stock 4G64 bottoms come with pistons designed for a N/A application. They don't have a friendly compression ratio for F/I nor are the pistons designed for it.
I have heard of people getting 300-330whp out of them using around 16psi of boost, but I don't think that will last very long.
nos51's Avatar
yes you hit it on the money.i dont want to blow on building another motor.the point is to throw in a stock motor and see what it will do very basic.not go for records i can care less about that.i guess im going to find out lol.worst case scenerio is i loose $500 in a stock short block if it lets go.anyone else out there?
Old Mar 8, 2010 | 08:56 AM
nos51's Avatar
well define "friendly compresdion"?my last motor ran 10:1 and did just fine but on e85.im sticking toi the e85 also with this new setup
Old Mar 8, 2010 | 08:58 AM
GPTourer's Avatar
I understand that, but you have better pistons and rings designed for a F/I application. You also have it tuned correctly. People who know what they are doing can run higher compression on a well tuned turbo car, but that doesn't mean the same as pulling a bottom end out of any N/A car is going to get you the same or better results. Especially not with pump gas. He mentioned nothing of E85, meth, racing fuel or anything else to help reduce knock.
Old Mar 8, 2010 | 09:05 AM
MuslimEvoFreak's Avatar
If I understand correctly I think he is referring to the stock bottom end. You can throw E-85 in all you want but that doesn't mean the stock parts will hold up since they are for N/A applications.
Old Mar 8, 2010 | 09:37 AM
nos51's Avatar
Yea I know all of this stuff......but this doesn't answer my question...trust me I know the difference between a motor built for na and a motor built for boost.a stock k series is built for na 11:5 compresion they make 550hp all they and hold it too.
Old Mar 8, 2010 | 12:17 PM
RyuEvoIX's Avatar
I worked with the stock 4g64 for years. Based on my experience the bottom end will hold 300-350whp all day long. I have not seen it pushed much further past this but an educated guess would be somewhere in the neighborhood of 400-450whp will probably be near the max of what the internals will hold.
Old Mar 8, 2010 | 12:31 PM
tscompusa2's Avatar
that sounds about right Ryu. not the strongest bottom end, but not bad either. Its like a 7 bolt 4g63 from a talon/eclipse
Old Mar 8, 2010 | 12:47 PM
dtrackstar's Avatar
You'd get more reliable info probably from a 3g/4g eclipse forum.
