bigger injectors do i need to tune
i want to go to ams 680 cc injectors do i need to go get a tune fo rthe car to run properly or will the ecu accomidate for the bigger injectors ie more fuel
just about any changes to a turbo motor will require a tune for the most part. turbo back exhaust, bigger turbo, injectors etc. also if you arent sure of these things you should consider not buying anything or trying to install any new parts until you talk to whoever is going to tune your car. you dont want to end up buying the same parts twice since you didnt have proper guidance on what to buy to achieve your goals.
ChicagoEvo9
Feb 5, 2014 03:30 PM
dprez25
12
May 26, 2012 11:05 PM
