View Poll Results: Hows your Shifter?
Yes my shifter is notchy!!!
147
84.00%
No my shifter is butter.....
28
16.00%
Voters: 175. You may not vote on this poll
Notchy Shifter Feel?
Old Nov 4, 2003 | 11:27 AM
EV0lut10n_8's Avatar
Angry Notchy Shifter Feel?
my Evo has an extremely uncooperative shifter. Doesn't want to go into gear half the time without force. I either have to make granny slow shifts waiting for the rpms to drop almost to idle. or i have to force it in. which results in what i think sounds like a grind and a thump. i cannot tell if this noize is coming from the tranny or the shifter itself
I already change the driveline fluids this past weekend to redline MT-90 in the tranny and 75w-90 in the diff and transfer. but i still have the exact same feel.
I have heard others saying that replacing the rubber bushings in the shifter makes a world of difference. I am just curious what everybody's input is on this....
Do you have a notchy shifter????
How did you fix it??????
Old Nov 4, 2003 | 11:40 AM
Karash's Avatar
I have not replaced my driveline fluids yet...but hoping that will make a difference.
Old Nov 4, 2003 | 12:23 PM
1QWKEVO's Avatar
I thihk it's the design on the tranny, fluids shouldn't have to be replaced... The tranny was build ridgid to handle abuse so it's not going to feel like a porsche
Old Nov 4, 2003 | 12:35 PM
Fireball's Avatar
Change driveline fluids...
Old Nov 4, 2003 | 01:42 PM
i already did change the fluids...any comments on the bushings...maybe this will help?
Old Nov 4, 2003 | 01:47 PM
Fireball's Avatar
Maybe you're just feeling what ALL Evo's feel like. The shifting is suppose to be very notchy and solid, not mushy like other 5 speed cars.
Old Nov 4, 2003 | 01:54 PM
Sano's Avatar
sounds like mine, do they change drivline fluids during the pitpass.
Old Nov 4, 2003 | 01:57 PM
BeenWaitin4Evo's Avatar
I had a bad case of the notchiness before I installed the ss clutch line.
Cleared mine up almost 100%. Still a little "rigidity" in the shifter, but I expect that from a performance oriented transmission.
Old Nov 4, 2003 | 03:10 PM
okijack's Avatar
I did the clutch line upgrade, changed out the fluids, and installed aftermarket metal bushings in the shifter. Made a huge difference. The gears engage a lot smoother now.
Old Nov 4, 2003 | 03:13 PM
silvrevo's Avatar
exactly where did you find the metal bushings, and exactly where and how do you install these?
Thanks!!!!!!
Old Nov 4, 2003 | 03:22 PM
okijack's Avatar
I bought my metal bushings from lancershop.com. However, last time I checked, they pulled them off their site because they were on backorder. The install is super simple. Just pull off the center console and you will see the plastic shifter base plate. Just pop out the old bushings and replace with the new bushings. Should take no longer than 30-45 min. Do a short shifter search on this site. A few people already posted about how to change out the shifter and bushings.
Old Nov 4, 2003 | 03:24 PM
okijack's Avatar
By center console I mean the covering that hides the shifter assembly between the seats not the part that holds your stereo. Sorry for not being clear.
Old Nov 4, 2003 | 03:43 PM
freedom's Avatar
Re: Notchy Shifter Feel?
It's all in the timing.
Old Nov 4, 2003 | 03:50 PM
Jinu0808's Avatar
Yea I kind of believe its the timing also because once in a WHILE it just happen to shift LIKE BUTTER for no reason and then the next day you LOOSE that butter shiftness and back to notchyness.
Old Nov 4, 2003 | 04:18 PM
freedom's Avatar
In my case without respect to which car it's like butter, and then there are those days....
