Strokers - what cam profile is ideal?
Old Mar 19, 2010 | 03:38 AM
  #31
EvoPower81's Avatar
Originally Posted by xRoguex
Thats what was just suggested to me.
I assume your car is a Daily Driver and you wish to have very well behaved cams as well thats why I wanted to know if they worked fine with the stock ecu.
Old Mar 19, 2010 | 05:09 AM
  #32
MrHouse's Avatar
I think GSC S3s should be good for your setup.
Old Mar 19, 2010 | 06:23 AM
  #33
xRoguex's Avatar
I think I may try the BF272's because I have them. But I will be installing behive/dual springs in the process so I will be able to change cams with ease at that point.
Trial and error?
Old Mar 19, 2010 | 01:07 PM
  #34
EvoPower81's Avatar
Nothing beats a try. I will be very interested in the results. I thinkim gonna try the Jun 272s
Old Mar 19, 2010 | 01:45 PM
  #35
project_skyline's Avatar
My friend picked up some cams from MAperformance that GSC made custom specially for the 2.4, you might talk to them. I believe its a 274 cam, custom ground.
Old Mar 19, 2010 | 01:52 PM
  #36
brk4sti's Avatar
I run the jun 272's with my stroked motor and my friend with a similar setup ran different cams I forget exact cams but I liked my jun's to be honest I dunno if I'd run anything else.
Old Mar 19, 2010 | 04:58 PM
  #37
EvoPower81's Avatar
Good to hear Im 90% decided. Hope this was on the stock ecu
Old Mar 19, 2010 | 10:24 PM
  #38
Kasey's Avatar
The stock ecu will handle jun272s with very little problems. A lot of guys are scared of big cams on the stock ecu, but there are ways to make them smooth.
Old Mar 19, 2010 | 10:28 PM
  #39
BLKCarbonEVO's Avatar
Really easy if you have MIVEC
Mikey
Old Mar 19, 2010 | 10:59 PM
  #40
EvoPower81's Avatar
Whats the purpose of having cams when u cant hear the sweet lope! . This however is not the issue for me , its the drivability that im concerned with as a Daily Driver. "BIG" cams come with duration which reduces vacuum. This can cause intermittent stalling and poor lowend drivability which I dont want. I prefer to lose some power while mantaining the near stock drivability with a less agressive cam.
Old Mar 19, 2010 | 11:09 PM
  #41
In case you didn't know. A cam on a 2.0 that would make the 2.0 not drivable will not have the same effect on a 2.3 or 2.4. That same cam would be streetable on a 2.4. A 288 cam in a 2.4 would be like a 280 in a 2.0. Big motor need big cam!
Mikey
Old Mar 20, 2010 | 03:51 AM
  #42
EvoPower81's Avatar
Mikey
That makes allot of sense Mikey!. Thanks for the insight
Old Mar 20, 2010 | 06:52 AM
  #43
Kasey's Avatar
Mikey
That does help also but with these new high impedance injectors I bet I could make s3s idle good. Should be tuning mine today and I may be able to get some idle videos for you guys.
William, did you ever call Greg?
Old Mar 20, 2010 | 07:59 AM
  #44
n2oiroc's Avatar
i talked to greg@gsc about cams for my 4088r 2.2 and he said the s3 will make less than the s2 until about 5,500-6,000 and will only peak 10-20 hp more. to me thats not really worth it to go with the s3.
Old Mar 20, 2010 | 09:08 AM
  #45
That would be nice to get some videos
Do a 274/280 combo. You will still have great spool and better topend
Mikey
