Breaking in Motor with E-85??
Old Mar 21, 2010 | 10:32 PM
omniprobe's Avatar
Is it safe to do so?
Old Mar 23, 2010 | 02:25 PM
omniprobe's Avatar
Bump
Old Mar 23, 2010 | 02:41 PM
awd2gen's Avatar
Should be fine. Just dont run 40psi if your worried about break in. Alot of people dont even bother to do a break in period. I never have done one. Just checked for no leaks and that everything was functionally correctly then strap on the dyno and go ***** out. Actually helps the rings to set better.
Old Mar 23, 2010 | 02:47 PM
erald01's Avatar
are you always going to run e85? did you change the stock oem fuel lines when converted to e85, because i wanna do it. I have heard if you running e85 all the time the fuel lines to be changes, does his hold true?
Old Mar 23, 2010 | 02:52 PM
mdsevo06's Avatar
Who built the Motor? This is who you should be asking.
Old Mar 23, 2010 | 02:54 PM
AWD Motorsports's Avatar
40psi right off the Lift and onto the Dyno and Never an issue.. If built right then there is no worries..
MIke
Old Mar 23, 2010 | 02:55 PM
KTriplett's Avatar
lines do NOT need to be changed. there is no reason that a "break-in" period is any different on e-85. not that i believe in doing so anyway.
Old Mar 23, 2010 | 02:57 PM
erald01's Avatar
thats what i figured but i heard some guys say that e85 being higher octane could ruin your lines. I guess ill be safe then.
Old Mar 23, 2010 | 03:01 PM
race gas is higher octane than E85.. Octane doesnt ruin lines and neither will E85..
MIke
Old Mar 23, 2010 | 05:16 PM
omniprobe's Avatar
Thanks guys. Doing 500 miles without boost, run some checks then off to the dyno. Can't do 40 psi we only have lower grade e85 so I have to be a little conservative.
