S2 cams on stock turbo overkill?
Old Mar 22, 2010 | 10:52 PM
TurboIX's Avatar
I was looking into the GSC S2's for my bolt-on E-85 stock turbo setup. Would this be overkill in your opinion?
Old Mar 22, 2010 | 11:03 PM
AWD Motorsports's Avatar
Not On e85 by any means.. Quite honestly we use S2 in 90% of our builds..
Mike
Old Mar 22, 2010 | 11:15 PM
sparky's Avatar
Originally Posted by Mike@AwdMotorsports
Not On e85 by any means.. Quite honestly we use S2 in 90% of our builds..Mike
Mike, do you suggest the stock springs and retainers in this case, or would it be needed to upgrade the valvetrain bits?
Old Mar 22, 2010 | 11:17 PM
I have atleast a dozen local cars running s2's on stock valvetrain with no issues.. Keep rev limiter in check and the car is fine with them..
Mike
Old Mar 22, 2010 | 11:22 PM
06MREvo's Avatar
I am about to use S2 with my build but I am doing Supertech Dual springs & retainers...
Old Mar 22, 2010 | 11:33 PM
TurboIX's Avatar
8k max rev limiter right?
Old Mar 22, 2010 | 11:35 PM
Stock turbo is not making power anywhere near 8k.. id set it to 7600 shift around 7200 usually..
Mike
Old Mar 22, 2010 | 11:43 PM
Evo_TK's Avatar
I use S2's with my stock turbo for now
Old Mar 23, 2010 | 01:02 AM
aka.ralliart15's Avatar
I had S2's in my stock turbo on pump gas, changed them out for Kelfords becasue of the breakages that were happening, I believe that was a core issue though and now everything is fixed.
Old Mar 23, 2010 | 01:34 AM
K1tt3n5's Avatar
Which felt better/ made more power in your opinion?
Old Mar 23, 2010 | 10:08 AM
JohnBradley's Avatar
I have ran both back to back same car, roughly the same conditions (varied temp 5*, humidity no more than 10%) and the S2s are worth more power. I have made 383-387 on a stock turbo with SD on 92 octane multiple times and 400whp once. I have yet to do that with the Kelfords.
Before we discuss the whole cam deal again, please remember it wasnt just the S2s. Piper, Cosworth, Kelford, Comp, and GSC all had one or more failures.
Old Mar 23, 2010 | 12:05 PM
Correct seems everyone had the failures but FP..
Mike
Old Mar 23, 2010 | 03:04 PM
Both of them felt about the same to tell you the truth. Again without back to back tests like the AMS one its all just speculation about which one makes the most power.
And yes I know a lot had failures but Kelfords were one of the first to switch their cores so I went with them...I was just talking about my situation.
