is coolant overflow needed?
Old Mar 23, 2010 | 03:36 PM
KTriplett's Avatar
weird question. is the coolant overflow tank needed?
i would think just running the line from the filler neck to the ground and adding a high pressure cap would take care of it. just yring to clean up the bay. i like empty.
Old Mar 23, 2010 | 03:39 PM
EvoDan2004's Avatar
please do not go dumping antifreeze onto the round. or road. leave the over flow. if you run straight water then fine. take it out but if you have any type of antifreeze leave it. also the over flow acts as a secondary reserve. if for some reason you get low it sucks it from your over flow back into the system.
Old Mar 23, 2010 | 03:43 PM
AWD Motorsports's Avatar
if it spits out onto your front tires and you go into a spin youll wish you had it.. Not to mention its functional if it spits coolant and sucks it back in..
Old Mar 23, 2010 | 03:46 PM
sivs's Avatar
it needs someone to go when it expands and thats where it goes dont remove it
Old Mar 23, 2010 | 04:28 PM
KTriplett's Avatar
ok well my next question is does it have to even with the filler neck? or can relocate it down on a frame rail out of sight.
Old Mar 23, 2010 | 04:32 PM
Yes you can send it down the frame rail sure.. I have mine in my trunk..
Mike
Old Mar 23, 2010 | 04:35 PM
KTriplett's Avatar
ok well that is good enough for me. thanks for the quick reply mike!
Old Mar 23, 2010 | 08:10 PM
05ah8james's Avatar
Mike
Trunk? Do you run the line under the car?
OP: Get a JMF Coolant overflow so it looks nice instead of the platic nonsense. Thats what I plan on doing eventually... not in a rush though
Old Mar 24, 2010 | 12:36 AM
KTriplett's Avatar
i dont care for any aftermarket tanks. i like EMPTY lol. but im sure mike ran his all the way down through his framerail. not sure though.
Old Mar 24, 2010 | 08:42 AM
mrboost05's Avatar
all you will need http://www.jegs.com/webapp/wcs/store...olent+overflow
chassis87
Dec 30, 2016 04:26 PM
MisUnderStood
116
Aug 10, 2016 08:31 AM
TeachersEvo
Jul 31, 2012 06:54 AM
gunnerman
27
Dec 18, 2005 09:12 PM
