new water pump leaking
Old Mar 24, 2010 | 12:55 PM
sleeper04's Avatar
well i did my 60k service, while i was putting antifreeze in the car i notice the water pump was leaking. has a new gasket and o ring everything torqued correctly.
anyone else have this problem? and any suggestions to fix it without removing the timing belt ?
btw i did a search
Old Mar 24, 2010 | 01:21 PM
Gary@MellonRacing's Avatar
is it leaking from the back ? were is like a drain plug ...
Old Mar 24, 2010 | 06:03 PM
sleeper04's Avatar
looks like the front of water pump....?
Old Mar 24, 2010 | 06:35 PM
DID u torque all the bolts ??
Old Mar 24, 2010 | 07:09 PM
Rome-Evo's Avatar
have you changed it out yet or have you priced how much it will be to get it replaced..?
Old Mar 24, 2010 | 07:33 PM
05ah8james's Avatar
Is it leaking from the o-ring or the surface where the waterpump meets the block?
Edit- my guess would be the o-ring. When doing timing belt services I've notices that if you're not paying attention to detail, the o-ring on the water pipe will sometimes not seat correctly. When I do mine I grease/oil the o-ring to help it seat in the waterpump housing. This would the first place I looked.
Womb Raider
Sep 26, 2016 10:55 AM
lghtngyello03
Mar 19, 2016 04:25 PM
Mauricio Evo IV
Mar 28, 2015 07:46 AM
NSS
Apr 9, 2010 04:07 PM
mt057
Jan 30, 2010 11:14 PM
