How much oil after Balance shaft removal?
Old Mar 31, 2010 | 12:28 AM
Shea561's Avatar
How much oil (quarts) are needed after BS removal?
How much oil (quarts) are needed with AMS's Balance Shaft Eliminator?
How much oil (quarts) are needed with BR's Balance Shaft Eliminator?
Searched and Searched and Searched....... counldn't find ANYTHING on this.
Thanks in advance for the help.
Old Mar 31, 2010 | 12:46 AM
jmelocik's Avatar
Oil Capacity won't change after the Balance Shaft removal, however you might see higher oil pressures because of the rotated BS bearings blocking off the previously used BS oil pasages. The AMS BS kit is actually a modified balance shaft and again, won't change oil capacity. The BR balance shaft completely removes the balance shafts and replaces the oil pump side with an original Mitsubishi stub shaft that has been used in many stock cars for decades. It has been proven to work well when installed properly.
The main reason for the balance shaft removal, in my opinion, is to remove rotating weight from the engine as well as remove a potential failure point.
Josh
Old Mar 31, 2010 | 09:38 AM
Shea561's Avatar
Josh
Thanks Josh. I'm aware of what it does and how the given kits combat/work with it..... I was just curious if any volume was gained by the removal or installation of these BS Eliminators that would necessitate more oil.
Again thanks a lot man. Very helpful.
fast03evo
Jun 14, 2015 05:33 PM
phil_
Lancer-Mirage Compatibility Forum
Oct 22, 2011 10:12 PM
raytrix
14
Mar 1, 2010 06:37 PM
Yamahar1
Jul 11, 2009 02:38 PM
SPOOLEDTSiAWD
75
Nov 25, 2007 09:09 AM
