Symptoms of a faulty IAC...
Old Apr 23, 2010 | 07:54 AM
awdboosted's Avatar
Originally Posted by black95tt
I did pull the coolant lines and clean the TB, but was careful to not clean off the special coating (whatever it is). The IAC moves and everything checks out. The car idles fine and drives fine, it's just when I start it back up when it's hot. It idles high as hell for about 5 seconds and then settles in. Starting when cold is no problem.
If you don't have coolant lines connected it will do that. Unless you block off the FIA.
Old Apr 23, 2010 | 11:15 AM
mifesto's Avatar
i also hear disabling the EGR will also cause temporarily high idle on a cold motor
Old Apr 23, 2010 | 01:40 PM
Evoryder's Avatar
^ not if you lowere the desired idle tables
Old Nov 13, 2010 | 06:48 AM
Liqquid's Avatar
Alright guys I've done all the testing listed here... when I remove the IAC and leave it plugged in to observe movement, when I turn the key ON.... it does nothing. when I turn the key back OFF.. it moved all the way out then back in.
?? isn' that the opposite of what it sould be doing?
Old Dec 19, 2010 | 02:17 AM
gracen's Avatar
how to test ISC motor using ohmmeter method and reading results
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
nytalonTSi
Jan 8, 2019 06:57 AM
Vehicle336
Aug 31, 2017 06:22 PM
Boombox
32
Jan 23, 2016 02:34 AM
blackmambe_evo7
Apr 11, 2013 08:57 AM
