stock block and head with Precision 6265 turbo
Old Apr 8, 2010 | 03:36 PM
MrHouse's Avatar
What FMIC are you running?
Old Apr 9, 2010 | 03:50 AM
CrashD's Avatar
FMIC is stock for now, but i have imported a blitz inter cooler which will be installed soon...
Old Apr 9, 2010 | 07:09 AM
Mellon Racing's Avatar
Originally Posted by CrashD
so u think using cometic gaskit is good idea??
FIY my Rpm have been lowered to 8500 with no knock.
u think the internals will take this amount of boost and still be safe???
I think the OEM gasket is a good idea, just because something is aftermarket that doesn't mean it's better, often it's worse
what amount of boost?
Old Apr 9, 2010 | 09:53 AM
CrashD's Avatar
1.9 bar boost......! 8500 rmp tuned with haltech on 93% octane.
Old Apr 10, 2010 | 04:19 PM
CrashD's Avatar
So tell me should I use the oem gasket or cometic gasket for my setup that is 1.9 bar boost with 6265 turbo @ 8500 RPM???????
Urz comments will be very helpful as I'm abt to install the duel springs retainers, ARP studs and gasket......!
Old Apr 10, 2010 | 04:46 PM
RockmanX's Avatar
oem headgasket is really all you need man other stuff is waste of funds. mellon car is 704whp all day on stock gasket and its fine. You will be too. your TQ Number will determine if you need a built motor personally anybody thats going to be doing alot of aggressive driving with high boost and lots of power needs a built motor in my opinion. Thats a big turbo your running and sounds like your hungry for power. Built motor in your future hommie
Old Apr 15, 2010 | 12:29 AM
BLKCarbonEVO's Avatar
if you rev that high on stock rod bolts you will throw a rod. I am exstremely shock that Mellon, Marti, or Rock has not told you that! -1 for you guys. His car will not make it reving that high Stock rod bolts should never never go over 8k.
Mikey
Old Apr 15, 2010 | 06:43 AM
Originally Posted by MrHouse
Nothing is safe if tune is not correct. If I was you, I would change internals to be on the safe side.
Mikey
Mikey, MrHouse already addressed that.
and I spun mine to 8500 for years on the stock shorty/head with a 35R and HKS 280 cams with stock springs and retainers I don't recommend it to my customers though.
Old Apr 15, 2010 | 08:34 AM
Jhutterer's Avatar
Good read.
Old Apr 15, 2010 | 02:34 PM
CrashD's Avatar
ok guys i have some great news i have decided to go for a full 2.0 engine built,
wisco pistons,
manley rods,
eagle crank,
arp head studs,
twin fuel pump,
haven't decided abt the cams, any recommendations??
ACL Rod Bearing, main , thrust washers,
etc....
what u guys think;, oo and the turbo stup is the same
any thing u suggest??
Old Apr 15, 2010 | 02:45 PM
beastly, Kelford 272 or gsc s2 always get good results for my customers
Old Apr 15, 2010 | 03:33 PM
CrashD's Avatar
thanks, decided to go for the GSC S2 just waiting for the parts to arrive... will update when i start the installation....
Old Apr 15, 2010 | 09:49 PM
wisco pistons,
manley rods,
eagle crank,
arp head studs,
twin fuel pump,
etc....
You should look at getting a 4G64 block and using a 94mm Eagle crank w/ 156mm manley rods. That would be a LR2.2 and you could still rev 8.5 easy but the extra displacement will help spool your turbo.
S2s FTW
Mikey
Old May 7, 2010 | 05:54 AM
CrashD's Avatar
things went a bit different than my last post ,
my tuner sugested that rather than going for a full built , i should go for cams:
so i have odered the following:
GSC,s2 cams.
gates timing belt .
aem uego.
full blown twin pump.
head work already include:
supertech springs
ARP studs.
cometic gasket.
and he will increase the boost to 2.2 bar @ 8400RPM. (6265 turbo)
what do u guys think with a good tune the internals of jdm evo 9 can take this much boost???
since we don have a dino in pakistan can anybody tell me how much HP my evo 9 should be making ... just a guess?
Old May 7, 2010 | 11:10 AM
CrashD's Avatar
bump!!!!!
